Hey all having a few issues with my new autech stagea and i bought a consult cable and put the software on my laptop but it wont connect to the comm port.
Also had another diagnostic tool on the car at my local performance shop which wouldnt read it either.
I dont know if anyone else has had this problem but as im just cruising the car surges like i am tapping the throttle on and off. Have change the coil packs, cleaned the afm's put a new fuel filter on but nothing seems to work.
Any help would be greatly appreciated.
Thanks
Ads
Dont think the consult will give you much information regarding your problem that you can't get from a manual ECU diagnostic, give that a try. Work through the usual suspects like, fuel pump & regulator, spark plugs, TPS, O2 sensor etc
What "diagnostic tool" did the workshop try and use? The reason I ask, is because I went through this with my pulsar recently, and after much arguing with the cable seller, along with repeated returns being tested by him as fully operational, I bought one off the ECUTalk guys (NewKleer on here and pulsar.org) I had no further issues.
Just be aware that all consult cables are not created equal. :P
Thought maybe the consult would show any error codes and if afm's and tps are reading properly
Yeah, it will, but you can get same information by doing it manually.
just do a continuity check between the wires on the consult port and the pins at the ECU (forget the check one, check there is 12v when car is on at 12v ign one, gnd to gnd, and the remaining 3 go to ecu).
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
