need a set of 17's or 18's for my R34. budget is $1300 but depending on wheels may spend more.
wheels need to have decent amount of tread left. located and melbourne and will pick up.
have cash ready to go so post up if you have anything.
ta
Ash
https://www.sau.com.au/forums/topic/269482-wtb-17-or-18-wheels-with-rubber/
i have some gtt stockies with lots of tread on the tyres... are you selling the car and want some cheap ones to throw on there or what?
i doubt youll be interested but cant hurt to ask!
Ric
not selling the car. just dont want 19's anymore. with my "handling" setup i prefered the feel of the car witht he 17's thats why im looking at going down to 17's or even 18's. so not after stock wheels thanks unless they are 350Z rims.
ta
Ash
hey mate... don't know if these are what you're looking for, but i got a set of amg alloys 17x8 front and 17x8.5 rear - currently on my 32 with miles of clearance from the brakes
front tyres are good, rears are almost new on the outside, but pretty bald on the inside due to disgusting camber when i bought the car
if you like em i'm happy to trade plus cash your way for the osakas, or i'll take a set of stockies (if you have em) with cash my way
pm me if you're intersted, pics related :devil:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
