i know theres a few threads on exhaust here but im going to do an exhaust on the 260 shorlty... im just wondering what i need? dumps, front pipe, and cat back... ive gutted my cat already. do i want the split dumps from just jap?? its 399 i think for them and 299 for the front pipes?
cheers :whistling:
ps i think the jap styling with the 260 may need a cannon but im not 100% keen :S im really unsure what tip i want? twin tips maybe?
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/
just had my front muffler removed today and replaced with a straight pipe.now it goes- advance dump/front pipe,gutted cat,straight pipe to a magnaflow cannon.sounds lovely and decibel tested it at the workshop,it made 92.8 @ 4000rpm.very happy with it now!
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4592533
cheers :)
There is nothing wrong with the JJR dumps and front pipes, there a copy of the HKS ones and are fine, just make sure the flange face is flat before fitting.
A mate had a set on his 32 GTR with 2860-5's, fitted up fine, with JJR front to, did 455rwhp @ 20psi, so worked fine to.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4594779
If you do a search on here quite a few people have mentioned that the stock GTR dump pipes are quite good. My 260RS has stock dumps, 3" Apexi front pipes, 5" cat, 3.5" cat back with 2 mufflers. The rear muffler is a Fujisubo Jasma cannon. It has quite a nice sound and is not too loud.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4595631
JASMA = less than 95dB
So depending on where you live, this can be fine or could cost you an EPA fine and a defected car (like in Victoria :P )
Edited by iamhe77
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4595819
cheers :D
I have the dumps and front pipe for less, front pipe is used like new and dumps are unsed.
pic
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4597888
So depending on where you live, this can be fine or could cost you an EPA fine and a defected car (like in Victoria :blush: )
Awesome. I did not know that. Hopefully with the 2nd muffler it would be under the limit.
https://www.sau.com.au/forums/topic/269860-260-rs-exhaust/#findComment-4598539
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
