chassis rails... fck that :P
although you could weld in the same type of steel and shape it correctly, grind back the welds and paint it matte, than stick some dirt on to it to make it look factory.
although i would not recommend it, you could getaway wit hit unless they have a closer look. if that's not your car, than please do not buy it.
ive been repairing chassis rails for a few years now, and thats exactly what ild do before you get defected and all attention goes to the rails. you may have to do a bit of cutting to youre bar and get a new reinforcement but least if you have a slight front ender it wont just collapse on ya.
ive had this car for ages now.. was like this when i got it..
only got about 70mm cut off the chassis rails.. im thinkin if i cut them straight and make them look like they were that short, people wont realise? cos its only 70mm trimmed off?
or i can get a air diversion panel to cover it up, so you wont see it.
Get it done now while you can do it on the cheap - get it looking as neat and clean as possible. IF regency spots it and picks on it then you'll need to get it professionally done and get it engineered = alot of $$.
I'd be paying a visit to the knob who sold you the car. :(
Even better, send him the bill for the chassis repairs. Thats seriously f**ked. :banana:
The only way I was going to fit a fmic to my car was without any cutting at all ... right down to fabricating return pipes to mate with the stock piping under the bonnet. No cutting, no trimming, no butchering.
I'd be paying a visit to the knob who sold you the car. :huh:
Even better, send him the bill for the chassis repairs. Thats seriously f**ked. :/
you just saying that or are you being serious lol? because... i dont think it would work lol
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
