The Stagea has a new, bigger smile ...
Before:
After:
Cooling Pro delta fin core yo!
:D
Took a whole afternoon to do it. Purchased the mandrel bends from Aussie Discount Mufflers and cut and welded it all up myself. Total of $69 in materials and a wee bit of my time.
Needed a new cooler to match the new bar. End result = one happy stag owner :P
Pulling it all apart this weekend to paint the piping. No leaks ... happy I can still weld.
Edited by RubyRS4
https://www.sau.com.au/forums/topic/270537-delta-fin-type-m-big-mouth-yo/
Looks nice, but perhaps you should move the number plate to allow all that air to pass through to cool the fins?
Yeah and get the fully sic lets go skidding s13 look. thumbs down. Dont think the number plate is actually going to make a massive difference to roo's airflow.
Looks good ruby. Think its time we organised another cruise. adam and I were in the shed till 2am this morning doing the turbos on his 260. Im so glad i have a 25 now lol , so much more space to platy with!
The plate looks good imo where it is now ... and its some 130mm from the mesh and 150mm from the cooler, so its not interrupting the flow. And in any case, its far more flow than the last cooler :P
Chris, yeah another stagea cruise would be awesome. I've got the SAU SA meeting thing this weekend and Kadina after that. Perhaps an end June cruise, or anywhere in between :huh:
good stuff
yeah mount the number plate like mine with a simple bracket
just got a metal intake pipe kit and a proper fmic pipe kit (battery feed), so getting them installed this thursday at dynotune
along with a oil catch can setup
just awaiting delivery of seat rails to tidy up the fitment of my new racing seat
some people move it to the side, which is what S13/S14/S15 drivers SOMETIMES do.........
Its also what the VL commonwhore and some R31 drivers do, to give that fully hectik "I don't have a fmic ... hell, I don't even have turbo ... but I wanna appear that way" look :dry:
yup see my sig ^^^ was there for around 2yrs
prefer the current position tbh
Tangles, you still got those driving lights? :D
Are they oem items? I traded mine off and regret it now ... looking for replacements. ;)
Edited by RubyRS4
looks good roo,fills out your viva bar nicely.me and fr33k just spent the last 2 mornings doing my fmic.got it cheap,apparently its a capa performance? cooler,bought it from the dude doing aleks dump pipe the other day.same side inlet and outlet,we couldnt quite get it in the middle of the bar so we just moved the plate over to hide that fact.came out alright i think,seen as we just used piping that was left over for other cars and projects
Looks good Rodney. Keeping it polished like I am? My last fmic was lightly sprayed satin black to keep it discreet. But this time I've gone for the polished look ... and blue mesh :)
Next big mod for me is the manual conversion for the car. Shopping around for GTR gearboxes now.
manual hay roo.... Im tossing up doing it aswell... Will you do it at home yourself?
Yeah. Buy the box and conversion stuff (pedals etc) and do the work myself in my workshop. Then take it to a transmission place and just have them check it all over. :)
Before:
After:
:rant:
Needed a new cooler to match the new bar. End result = one happy stag owner :)
Hey hey. nice car man, looking good. I was just wondering; what intercooler is that, and how much for purchase/installation?if you dont mind me asking. im just getting a vague idea of prices etc..
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
