hey guys,
Just wondering if anyone can give me the details of some where that supplies paint to suit my skyline, i have the name of the paint and the code just stuck as to where i can buy it. i have all the tools just cannot find the paint.
Any help would be appreciated
:P
https://www.sau.com.au/forums/topic/270711-car-paints/
oh ok do you know how long they take to make them up and if the quality is any good? Iam guessing all i need is the paint name and code? Do all supercheaps make up paint or just a select few? Thanks for that info Gaz.
Edited by phenline
https://www.sau.com.au/forums/topic/270711-car-paints/#findComment-4603673
auto1 mixes paint.
also, theres a place called auto power or auto paint, in balcatta, on the corner opposite near geddes st that mix paint pretty cheap.. and is a specialty car paint shop too.
That balcatta one is great. They dont just go on the code, they compare your actual car and it usually ends up being slightly different. They even put the paint into a spray can for you for those real backyard spec paint jobs. Nice people too.
https://www.sau.com.au/forums/topic/270711-car-paints/#findComment-4605454
There are a few paint places in perth as far as paint goes its all the same quality.. for the actual stores dont know about the quality for supa cheap.. and auto1
TOTAL PAINT SUPPLIES (9248 8812)
Unit 2/19 Vale Street, Malaga
(GREAT FOR SMALL THINGS - Car filler - Mixing things ect..)
APC (9272 7023)
Unit 1/30 king Street, Bayswater,
BEST FOR PAINT it cost me $695 for all paint and thinners to pait a whole car and kit.. (4-1Primer,5ltr of my silver,2-1 clear, 20ltr thinners, 4ltr prepsol)
Premier Paint's
Beach rd.. malaga near NEW bunnings
NOT CHEAP BUT GREAT QUALITY
https://www.sau.com.au/forums/topic/270711-car-paints/#findComment-4607057
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
