Time to say goodbye to my godzilla :P
This car has been my baby for the last 9 months but its not going to fit into my life plans ;)
Im looking to sell and buy a BA falcon XR6 or something similar, so im open to hear some trade
sugestions.
R32 GTR with 88xxxkms (nismo dash reads 31xxx).
-Nismo coil overs
-3" catback exhaust
-Xtreme HD clutch less than 2000 kms old.
-Turbos less than 3000kms old.
-New brake pads (bendix) and Just fitted the front brake calipers with new seals and done
a complete brake system flush and bleed.
-18" rims, tyres at 85% tread.
-R34 GTR v-spec Fuel pump
I have also got Gates racing aux belts but havent fitted them valued at about $30 each.
The car has recently had a powerFC and 700cc injectors fitted (sards), tuned by martin at willal racing.
GT2860-7s @ only 15psi. The car made about 260kw at the rears on a Trueline dyno (american dyno), which equals about 285-290kws on a dynamic dyno (australian dyno). With Front pipes and Hiflow cat, this car would see an easy 310-320kws.
price is $20k
mob 0433228859 cheers
pics will come later tonight :)
https://www.sau.com.au/forums/topic/270719-r32-gtr-1989/
$18,000
come on guys!
i want this sold!
hit me with some offers!
interested in swap for 06 VZ maloo ute and cash my way?
red, 6 speed manual, 6L LS2, under 50,000kms, still under new car warranty. In Adelaide, rego is 6L (custom plates).
https://www.sau.com.au/forums/topic/270719-r32-gtr-1989/#findComment-4649663
would be after $20k+ and your car as trade (Paid well over $50k + on roads 2.5 years ago). Just placed an ad on carpoint/carsales. Will link as soon as it is up. For the mean time, here are some snaps.
https://www.sau.com.au/forums/topic/270719-r32-gtr-1989/#findComment-4652388
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
