lawl you cant see the snail char....
Umm really you'd be better off doing the work yourself, mechanics will do the work if you really want them to. Costs money though when generally its not too difficult to do it yourself.
kk i might as well give it a go.just dont wanna screw anything up aye thats my main worry.......
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4607019
Dont pay a mechanic to do it, its not too hard.
Start off with painting/polishing your rocker cover and spark plug cover. Next, take all your intake piping off and get it sanded/polished. Looks mint when thats done. Relocate your fuse box to under the dash, hide your overflow bottle and washer bottle, and carbon canister. If your more serious, hide all your wiring, get a GReddy forward facing manifold, and a highmount turbo. Then go nuts with the chroming/painting until everything is perfect.
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4607047
+1 easy mod is take off your fuse box lid and sand it back so all the writing is gone then sand with p800 and give it a coat of plastic primer and head down to supa cheap autos get ur self a can of 2pac. spray paint and go nuts.. then mabe a coat of clear that will give u a gloss shine..
if u FU*K it up go to reckers and get a nother one for 10buks
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4607086
well if used correctly it is lol, ie:bleed the brakes/clutch :P but yeahh, im a 3rd year nissan apprentice and i can tell you right now i guarentee that if your gunna work on a car you'l always find something to cut yourself on no matter what your doing :sick:
Yeh very true, i sliced my thumb open when i was replacing my gear knob :(
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4608556
not too good aye..what parts can i pull out that arent necesary?
There is a big reservoir attached to the firewall on the drivers side. You can remove that, it isn't necessary for going fast or doing skids. :P
No but seriously if you want to do it properly it is going to cost big dollars. (ie. chroming everything you see, rewiring the engine bay so all the wires disappear, painting various things). Just enjoy your car and put some money towards some basic mods like a good stereo, exhaust, some nice rims and whatever else you would like to do.
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4608870
Man, you could practically eat out of that engine bay it's so clean.
When rooting around in your engine bay, you will bleed no matter what, you don't even have to be doing anything major, and you will still bleed. And when you do, you usually won't notice it until you start bleeding on things you shouldn't ............ Fkn RB30's in VL's **shakes fist**
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4615780
We generally use the search function to be honest.
Come to a meet or something, ask around for Greg.
I can talk you through some things.
It gets pretty expensive once you get past the suggestions made by Michael on the first page.
ok i shall do that
where a meets?
what are they?
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4618816
i was just wondering what about the "engine bay wash" at those kwik kleen DIY carwash in?
anyone have tried that before, i was just thinking to clean it just a little not up to the std of showroom look?
or should i just stick with a steam cleaner?
how do u guys clean ur engine bay anyway?
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4618946
check the events section. At this point I'll be going to the cruise on saturday.
I clean my engine bay with degreaser and a hose.
Wrap up my reservoirs/alternator/fuse box/fill the coilpack channelo thing with rags then plastic on top/ i think im missing something else.
Spray degreaser, wait 15mins, spray water, scrub anythign that didnt come off easy right away, leave bonnet open in sun to help dry.
Couple hours later, unwrap reservoirs etc, give those bits a wipe down.
done.
This has been done once ever. Waste's a good few hours.
https://www.sau.com.au/forums/topic/270820-new-car/page/2/#findComment-4619591
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
