I was just about to buy a set of Tanabe Sustec Pro NF Coilovers. The supplier came back to me asking if I have Hicas or not, apparently if you have Hicas the coilovers can rub on some of the machs.
I am still to establish wether or not I have Hicas or not, however I am under the impression that if the car has Hicas there is a dash light which will come on when you turn the ignition. There is no Hicas light on my dash, so unless the bulb has blown I am assuming I don't have it.
I have had both gtst's and gtr's with Hicas, and there is always a dash light on ignition.
Any-one had any experience with any of the above
https://www.sau.com.au/forums/topic/270935-nm35-hicas-and-coilovers/
Hi Nick
If your car has HICAS you will have a light that comes on with ign.
You can see the HICAS control on the back of your rear sub frame. When looking under from the back it looks kind of like a wiper motor blocking the view of the diff. Mabye you could google and get a picture.
Muz
Completely off topic, unless you have something rare you mispelt Stagea in your profile :ninja:
Only a few of the models had HICAS, it's not a common features except for the
If you want to make double sure you could probably get someone to FAST the VIN Number and confirm if HICAS was factory fitted.
(extracted from Wikipedia)
  • 250tRS FOUR V HICAS: A 250tRS FOUR V with the addition of the Nissan HICAS four wheel steering system
  • AR-X FOUR: A 250t FOUR (ie 2,5L turbo/4wd) model with increased ride height and SUV-like body ornaments. 206 kW (276 hp)
  • The were 4 'aero selection' models added in 2002 to the 250RS/250tRS FOUR/250tRS FOUR V/250tRS FOUR V HICAS ranges, this added a bodykit to the standard car
Hi Nick
Muz
Thanks, there is no light and nothing blocking the diff. Suspension and hubs all look ok. Don't think I have Hicas.
Its like a disease
Completely off topic, unless you have something rare you mispelt Stagea in your profile :D
Seems as though the 250t with Hicas also had a bodykit, I have no body kit therefore I have no Hicas
yeah just take a photo and we can tell you
also, i have the body kit and i DONT have hicas. then again i have an RX and hicas wasnt an option. it was on RS. ARX all have them, and AXIS im not sure
OK, I will look for the pump thing and take a photo. Thanks
no no i know wat it looks like...
well near the diff area a massive plug looking thing...
Can someone with HICAS please post up a pic so us less HICAS-ologists have a better understanding of what to look for or be prepared not to see under our stags. . .
Maybe this will help........
Sorry the quality is pretty crap but it will give you the idea.
If you follow the exhaust towards the middle of the picture, you will see the anti vibration thingy (round piece of metal) and then just above the that is the black cylinder with a Nissan sticker. This is the electric motor of the HICAS. It connects on the right to the gearing that changes the angel of the rear wheels with the turn up to 1.5 degrees.
Cheers
Andy
Cheers
Andy
many thanks mate. . will check in the morning
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
