I have 5x 19" Maas Wheels for sale with Falken FK452 tyres.
19x8.5j
offset is 35+
tyres: 245/35ZR19
max load: 1600lbs
the spare wheel has lip damage, but still holds air on 98% tread tyre.
the other 4 tyres have atleast 85% tread, except one that has some camber wear.
Other than the spare wheel, the other 4 mag wheels are in good cond. one that has minor gutter rash.
Selling due to reducing wheel size, to a 17" wheel ( something similar of a driftek, and light)
come and grab a set of nice wheels to set off your car.
PRICE : 1200
thanks
Please respond via PM
https://www.sau.com.au/forums/topic/270963-5-19-maas-wheels-5x1143-offset-35/
need these wheels gone people.
very nice looking wheels.
i bought my drifteks, so the 19's are just taking up space now.
have had a couple of offers, and the wheels i thought were going to be gone tonight, but no word.
i'll take 1000 now. first in, gets them.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
