Gordon!! Gordon!! Gordon!!
should'a borrowed it while it was sitting there for 3 months chop :D I'll check how its running, if the oil has gone bad i'll change it, so if i do you can borrow the sump plug.
anyhow, 2 hours 39mins i will have my car back .. not that i'm counting or anything.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
