Wrecking 1998 Stage series 2 most parts available
RB25DET neo motor complete with turbo loom ecu etc 109,598k's $1500
Auto box $500
brake calipers $200pr
rotors $100pr
factory wheels good tyres missing couple caps $300
3 inch cat back exhaust jasma rear mufflet $350
weathershields $100pr
floor mats $100 set
doors $100ea
door trims $70ea
side mirrors $70ea
speedo cluster 109,598 k's $150
steering wheel no airbag $100
window switches drivers $50 others $30ea
auto gear knob $65
cup holder $60
centre console $100
seats $300 set
dash fascias from $30ea
climate control $140
clock $40
factroy suspension $130pr
outer tail lights $100ea (no inners on tailgate sold already with tailgate)
sunvisors $35pr
various trims carpet etc from $5
Plus much more as I have complete car with front end damage. PM me for more parts/prices etc
I am located in Jindabyne NSW but can send parts either post or by courier
Thanks
Daniel.
https://www.sau.com.au/forums/topic/271300-wrecking-1998-stagea-s2/
  • Replies 73
will take all parts as per PM i cannot reply due to inbox settings will PM you when i can
Auto box $500
rotors $100pr
floor mats $100 set
doors $100ea
door trims $70ea
side mirrors $70ea
auto gear knob $65
cup holder $60
centre console $100
seats $300 set
clock $40
sunvisors $35pr
Thanks
Daniel.
i'd have to have a look tomorrow how hard to remove the rear 1/4 windows see whats involved and get back to you.
there is a thread on here some where on how to do it safely. caust the copper wires running into the window can shatter it if your not carful.
and cause my car's getting a respray end of the year. be good to have back up incase they do the same mistake. and i have to get clear ones
ok will have a look for thread..is it something to do with heating wires up.
will let you know how i go
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
