hello all i have some parts of my engine i no longer need as i have gone RB26/30 and single high mount turbo i have some various things fo sale so here we go
2 air flow meters with apexi filter and metal intake pipe $250 pair
2 standard 32gtr turbos $150 each
Trust twin dump/front pipe $200
Apexi twin blow of valves $180
standard pistons and rods $200
rb26 linished crank with jun collar $550
i also have all the oil lines for the turbos and twin turbo intercooler 2 into 1 ypipe and maybe some other stuff i cant remember right now pics up tomorrow
Edited by GTR180
https://www.sau.com.au/forums/topic/271717-parts-for-sale-rb26dett-r32gtr/
hey mate, interested in the oil lines, plese Pm me with a price posted to 2474
cheers
sorry mate oil lines are on the turbos and i dont want to take them off as its easier to sell the turbos with the lines on
i made a mistake on the first post i was meant to write water lines not oil lines sorry
as for the water lines they are the ones that go from the turbos all the way around the back off the engine to the intake side
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
