Hi guys for sale i hav:
RB25det with turbo, loom (to suit a r32), ecu, spitfire coil packs, afm etc $2300neg
will sell motor without turbo.
r32 manual gearbox $500neg
a set of 18"x225 multi 4 stud with tires(2 only 2 days old abit grazed, other 50%)
came off a r32na. $520ono
left hand door in good condition only missing mirror and door card. make a offer.
right hand door damaged. make a offer.
clean dash pad, vents hav already been sold!
some 5 stud conversion parts.
heaps of other parts, parted a whole car.
everything must go asap. just ask if your chasing something.
will post at buyers cost.
pm or call me on 0427140628 after 4pm wk days anytime wkends.
cheers kel
Attached thumbnail(s) img-resized.png Reduced 77%post-53788-1243160685_thumb.jpg 640 x 480 (109.63K)//img-resized.png Reduced 77%post-53788-1243160707_thumb.jpg 640 x 480 (102.29K)//img-resized.png Reduced 77%post-53788-1243160738_thumb.jpg 640 x 480 (78.23K)//img-resized.png Reduced 77%post-53788-1243160809_thumb.jpg 640 x 480 (102.38K)//
img-resized.png Reduced 77%post-53788-1243160843_thumb.jpg 640 x 480 (133.84K)//img-resized.png Reduced 77%post-53788-1243160883_thumb.jpg 640 x 480 (106.07K)//img-resized.png Reduced 77%post-53788-1243161013_thumb.jpg 640 x 480 (100.39K)//img-resized.png Reduced 77%post-53788-1243161034_thumb.jpg 640 x 480 (90.09K)//
img-resized.png Reduced 77%post-53788-1243161074_thumb.jpg 640 x 480 (117.82K)
Edited by The Gun
https://www.sau.com.au/forums/topic/271719-rb25det/
turbo x-trail:
not really keen to separate turbo from motor atm
was thinking of keeping it myself if someone didn't want it.
BUT! if motor doesn't sell in a few days or a wk or so, will be willing to start selling bits off it, need the cash
as i should be picking up my r32 gts4 tomo or fri.
will pm you if i decide to.
same goes with the coil packs
nos man:
as far as i know its a s1 with 85k on it
Anyone know how to tell the differences so i can confirm??????
Motor will also come with a mines ECU not sure whats done to it came with the car but never hooked it up.
https://www.sau.com.au/forums/topic/271719-rb25det/#findComment-4620016
PM sent to BOZ22N
ATTENSION!!!!
motor now will be sold without the turbo, hav decide to keep to put onto my gts4.
the TURBO that came off my gts4 is now up for sale i beleive it is a t30 (will confirm tomo with a price)
MOTOR is now up for sale for $1750ono
Edited by The Gun
https://www.sau.com.au/forums/topic/271719-rb25det/#findComment-4655971
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
