  • Replies 343
Posted Images
Which is a bit of a problem when one of them is the server. So you, with a 200+ ping, are playing against people with a 30 ping and one person with 0. Console players might not notice or care but PC FPS players won't stand for that shit.
It's like going back to dial-up.
Edited by DivHunter
ok soooooooo .... im sorry i don't understand the technical speak of ping and such - infact the last 10 or so posts make no sense - i have a PS3 - can someone break this down for me in baby terms please?
during the day you'll find it will connect mostly to american servers as its their prime time.. i find playing from about 9pm - 10pm onwards you mostly get chucked into games with plenty of aussies..
one thing i hope they add (probably too late) but an option to start your own public game.
Edited by defari
Those that think a second set of matching servers in the US won't effect them because they are on console...well we'll see.
Generally when a master server responds with servers it has found the list is populated with the servers closest to the master servers first, because they are closer so it takes less time. So when you have a master server on the other side of the Earth and you can't see the list of servers available you are at the mercy of the logic that the IW matching system will use which will most likely be optimized for, you guessed it, the US.
There's a reason they added server lists to L4D.
Also most consle players won't be able to tell the difference because FPS on console is so damn slow. I notice a difference between a sub 30 and a 50 or greater ping in my game play on PC, it's obvious and frustrating and I have changed ISPs over less.
As it has been explained it is P2P with a negotiated connection through IW servers in the US.
They really should have hired a network engineer instead of Bowling.
This is exactly the problem, you shouldn't need to flood the system with local P2P servers to be able to find one close to you. It shouldn't matter if there is 1 in 10000000000000000000000000000000000000000000000 that has the lowest ping, it should find it and connect you, but it won't and then two other people will join and max out the host's internet connection and you'll all lag out.
Or they might ad anti-lag...which isn't anti-lag at all just artificial lag for anyone with a decent connection.
If they had done it the other way around and announced the ability to host dedicated servers for consoles on regular servers, even if the hosts had to pay for it, this would have been met with much rejoicing and less about Bowling be a console molesting kent.
Edited by DivHunter
I was a PC gamer before moving onto the PS3. Been playing COD4 since it came out and you are right a bad ping is annoying as hell and even if they never planned on releasing dedicated servers for a console they should at least include a server list that shows the pings from the user hosted servers. I can't wait for MW2 as COD4 is getting really old and thankfully I am now in my final tourny for COD4 but they should improve the online experiance not just add more guns/perks. The console host migration has been updated but it never really worked in w@w and I will be suprised if it works as well as they claim in MW2.
haha divvy, 30 ping to 50 makes eff all difference (at least in tf2 or CS:S), so stop trying to mask a clear lack of skill! :)
I was going to post the screenshots in my photobucket from when I played COD4 and even FEAR but then i realised you wouldn't recognise anything that didn't have a beardy guy with glasses and a crowbar.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
