  • Replies 343
Posted Images
Online is crazy... my bosses 13yr old son owns me... mainly because he plays for 12hrs straight on the weekend!
Takes a while to learn the maps and where people camp etc... I was sick at home for a few days last week and managed to go from terrible... to fairly average lol
Best killstreak so far is 8... I'm going to keep playing til I can get a go of the AC130... at this rate I might be playing for the rest of my life!
hahahaha- this is why i don't play online - i'm happy being like "oh man i finished the game what an accomplishment"
I usually do the same, but after finishing it in about 4 hours, I wanted MORE. best game I've ever played, right up til I got flash banged by "Iwantmymommy69" :down:
also anyone who is interested in a little cheat do the following
make 2 classes, select your guns etc etc, but make your perk "one man army" and chose to have a claymore on both the classes you made..
when you lay a claymore down, find cover, press Y or triangle (ps) it should say changing kit (takes like 3 seconds)... presto, another claymore + full ammo again... lay that claymore down, press Y or triangle again, should change kit, presto infinite claymores +infinite ammo (however you can only have 2 claymores set at any time, by placing a third claymore down it blows up your first claymore)
so much fun, online is what this game is about, campaign is just training mode for the basic buttons. getting pwned is what its all about, and yes earning the maps and camp spots is the only way to avoid this. but its sooo much fun, and if like me you just dont care how much you die, get a shotty, and your sub machine guns akimbo and just run around like a mad man ;) sometimes it works, lol
i have levelled up to about 36 and am still getting my backside handed to me by these freaks who haven't stopped playing since they got the game, there are players out there who have levelled up twice - TO THE MAXIMUM:70!!!
yeah thats the fkn annoying thing about having rankings, is the losers who just sit on there 24/7 and pwn everyone until you have the reflexes of a cat with a caffiene addiction.
I'm just playing CS:S til I have the $ to buy the 360 version n go online haha
I got nuked two nights ago in 5 out of 8 free-for-all matches I played. This would happen within 3 minutes of each game.
Eventually I found out some clan, KAo$, were all hiding in the one corner, using tactical insertion and just shooting themselves so one of their teammates could get the nuke.
The use of a bit of cold-blooded pro and ninja pro changed this... along with my little gooey toy, Mr semtex grenade = multikill frenzy
Add me - ee7eye
My clan name is R33... but I seem to be the only member haha. I could use a few more.
Or you just use the scavenger perk, you are a sitting duck when changing with one man army, and you dont have to pick another class, you can just choose the same class that has one many army and it will restock everything
anyone keen to start a sau clan on ps3?
Sure, why not??
How many people on here use stopping power for every single one of their classes?? Unless you're a sniper class, there's no need to use it. It's annoying when I spray bullets at my enemies, only to have them shoot me twice and get the kill.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
