  • Replies 343
Posted Images
I had no luck at all connectiong last night!
Thought the private match worked perfectly...too bad there was only 2 of us lol
Yeah figured out that the only way for me to play is to join friends sessions....
To bad everyone is like level 40+ and i'm J-U-S-T on level 4....
Sad...
If anybody wants to add... Big_Amph
we had a party of about 4-5 of us last night
There was me
RBPOWA (TRJ86)
omgtr
another mate of mine (mehehe66)
and NateR31 (Natious) came in and out a few times
Big Amph joined my session for a bit later on as well.
Doh i knew i should have gotten on...girlfriend had other ideas though, apparently vampire diaries rates as more important!
There was me
RBPOWA (TRJ86)
omgtr
HAHA, that was you guys!!!
Sorry for bringing the team down, my palty 1-5 kills v 15 deaths...
SAD SAD SAD...
I'll more than likely be playin tonight til late for those on PS3
If I see you on Dezz I'll jump in
I didn't prestige for a while then got bored and thought why not... then immediately regretted it
I struggle to get my kill/death ratio up as I can't stand being in one place for too long and prefer rushing into stupid places blazing away and throwing grenades lol
Bunta: that's why we have another TV/DVD player in the bedroom, and why I download all my wife's favourite shows for her;)
I have decided i am really shit a MW2, i never get kill streaks! I did get harrier strike for the first time the other night but couldnt work out how to use it properly and ended up bombing a big patch of nothing lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
