Hey guys I have a 94 R33 gts-t auto and loving it and wanna change the coils ,as one is definately playing up, problem is its definatly a ser 1 R33 but seems to have ser 2 engine/ignition maybe swaped by previuos owner,
anyway how can i be sure? there is definatly no ignitor located on in near or around the coil loom, I have followed it back down the harness so I was thinking that if someone could post comfirmed ser1 or ser2 coil pic i could see which is mine ive searched this a bit now but nothing seems to get confirmed. I have learned from all my reading that im getting spiltfires Im lovin this forum cheers
https://www.sau.com.au/forums/topic/272008-confused-as-to-which-coils-to-get/
Wow, that was quick. Front facing intake? Makes it a WHOLE lot easier. It's kinda hard to tell for me, but they look like series 1's to me. Pretty blurry pics though, and I've only seen series II a couple times before, so I'd wait on confirmation from somebody else. Have you though about trying to repair them? Their are several write ups, but the two main ways are a insulative coating and cleaning out the brass/aluminum contact under the boot/spring with a dremel or some sand paper or something. Try both :(
yea its just a std R33 with intercooler. I want the better coils just for piece of mind just a coincidence one failed today. hopefully i find out tonight so i can airbag some. cant belevie the mark up on these things loclaly $1150.00 fitted :(
It's not hard to "refurb" the coils if you want to just give that a shot, and they do go out ALL the time. Pull the little rubber boot off the bottom, twist the spring out careully as not to bend it (not that it really matters unless you really bugger it up). The stick a dremel or something down in there to clean out the crude until you see shiny metal. Might want to hit the top of the spring with the stone too. After you get it all back together, put several coats of "flexane" or something similar like silicone sealant or liquid electrical tape on the outside of the coil to help stop it from arching.
man i type slow 2 replies will im repling hehe
ok definatly there is no ignitor present the coil harness ends into a plug then diaapears I have seen the pics of ignitors on this forum so im clear i no what im looking for
sounds like engine was swapped just need sumone to say yep that is a ser 2 coil and im laughing
I'm bettin S1 but you need to answer my question to know for sure.
:) ok we all agree
1. the pic are really shit
2.3hole on coil is s2
3.Car is a 1994 ser1 R33 auto running ser 2 parts
4. those pics where really shit
Thanks for the help guys im thinking of going supa sparks based on feed back in the forum is there any real reason for getting splitfires if not seems like im paying for a brand not a product. the extra cash could go towards tyres :/
:) ok we all agree
Get some yellow jackets coil packs and save even more money towards better tyres :D
Performance-wise has them on his site for about $380/set - www.performance-wise.com
Ive had a set of yellow jackets in my car for about 5 months now and they havent skipped a beat.
Plus they come with a 12 month warranty and wont melt like the super spark or JJR ones have been known to do.
Edited by d_liberate
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
