This is most definitely a silly question but I am after a straight answer to rid my curiosity.
I have an Autometer Oil Pressure Gauge (electric). Attached is the wiring diagram for it. Basically I would like to know if I am able to bridge the 12V lamp wire to the 12V gauge terminal (going to ignition switch), and the ground lamp wire to the ground gauge terminal. The benefits of this would be a reduction in the amount of wires going out from the gauge. The only downside I can think of would be the drag the bulb has on the gauge power source, whether or not this will interfere with the accuracy of the gauge I do not know. What do you think? I am not an electrician so dont judge me :D
you can connect the grounds together then run 1 wire to ground but if you connect the light and positive together the light will run permanently not just when you turn the headlights on. if that is not a worry there is no reason you cant wire them together..
Thanks for the reply Pudz. Yea I have no problem with the gauge being lit up permanently, was more concerned about whether or not it had an effect on the gauge reading. I guess I will give it a shot and will see what happens.
wont affect the guage reading. that is taken from the signal wire. all earth wires connect together anyway. and if you dont worry about it being on all the time then wire them together.
I actually had second thoughts when installing the Oil Pressure Gauge. I prepared another wire for the globe and was going to connect it to a 12v light switched wire. I thought I could simply tap into the dash light wire but found it was only getting 5V with the light switch on.
In the end I got over it and wired the globe straight the 12v ignition wire. Gauge works fine, globe works fine. But lets see how long it lasts before it burns out :)
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
