ok heres how the story goes. ive got 2 bosch 044 pump feeding off a 4lt surge tank. they lead off to twin -8 lines then aare joined into one at a -8 y piece i then have -8 all the way to the front with an inline filter (earls screen type) which then joins onto another y piece then to twin -6 lines to each side of the rail.... hardline all the way till i reach the -6 area. now the problem is wen i have both pumps running i have this very strange like choof choof choof noise coming from sumwhere its very hard to locate as the pumps are so loud but as soon as i switch it back to one pump the noise goes away. im very worried that the pumps are fighting each other or sumthin at the y pieces or there is sumthin goin on with fuel pulsation or sumthin because i dont have a damper like the factory cars do. has neone had a similiar problem or neone know how i could resolve this issue?
https://www.sau.com.au/forums/topic/272119-twin-bosch-044-strange-noises/
maybe. idealy if you have two 8mm lines going in to one line you would want that single line to be bigger? perfect setup would be two seperate lines? how much power are you making? is two necessary? maybe get one pump to supply it all? nismo?
just a thought... that noise is not heaps of fuel pouring through your surge tank overflow pipe? one pump would not be chucking as much fuel back in to your main tank?
i will be in the vacinity of 600hp maby more i could probably have run one pump but i wanted to run 2 just to have the extra bit there if its needed... on 1/2line should be plenty enough to do the job.... if it comes down to it im just gonna have to put in 2 3/8 lines. just means ive wasted alot of money on y fittings....
and no it wouldnt be the fuel pushing itself back into the surge its a 4lt surge so its gots plenty of juice to circulate.
i never said fuel pumping back in to the surge. talking about fuel pourng from the surge in to the main tank... if you have wayy too much fuel coming up from the lifter pump and too much fuel pressure going down the line then the overflow pipe will be chucking it back in the main tank... maybe you should check it out.
i'm having a wild guess but it's all i can think off ?
Edited by GT-RZ
well yeh of course its gonna be puting fuel back into the main tank thats a given but for sum weird reason it makes the noises alos near the y fittings..... as if the colliding fuel is causing the noise..... im considering just runing one pump and leaving it at that for now and if i start running out of fuel lata which no doubt i probably will ill run another line and get the other pump working hopefully...... its just a very strange thing
  • Like 1
if you are using a Vi-PEC you can program it to turn on the other pump at higher rpm or boost.
yes but wats the difference if its still gonna do the same thing..... ive been thinking and i thought maby the return back to the main tank isnt large enough to cope with the fuel flow coming in and out and maby its putting pressure into the surge tank which intail would be putting pressure on the wrong side of the fuel pump aswell..... just a thought....
im running the same setup with an 044 lift pump & 2 044's to my dual entry fuel rail.
what ive done is use the existing 'in' & 'return' lines as my 2 'in' lines & ive ran a new return line (as recommended by rips nz)
this should alleviate your problem & its an easy fix
HAHA Youre using a 044 as a lift pump? Thats just stupid. Why? It will just heat the crap out of the fuel and cause major issues. I would use a specific lift type pump instead. haha.
Back on topic, it seems really silly to have 2 of everything then just joining it in the middle...im just day dreaming here but wouldnt this be the same scenario as a tuned length exhaust?
If the 2 pipes arent the same length it causes bad resonation and loss of power. In your case the choof choof choof maybe. Just guessing. I would run 1 -06 line from each of the pumps and put them into each end of the rail. Then to reg from middle of the rail and back to the tank from there. Simplest and easiest way IMO.
these were my thoughts as i wanted to run the factory pump as a lift (seems over engineered this way TBO) BUT when i spoke to jim @ crd he said "stick with the 044, much more reliable"...i think he knows his stuff
2x 044 pumps running continuously on a street car is a dumb idea. First off there are very few regulators that will return enough fuel back to the tank without causing a restiction; hence increasing fuel pressure. Then there is the additional heating of the fuel. If you must have a surge tank than at least switch one of the pumps on when you think it will be needed but dont forget to put a oneway vavle in front of both pumps.
Ohh 044 as a lift pumps is shit idea - dont care who said it.
Edited by rob82
2 pumps... No one way valve...
When you turn one pump off, you do realise fuel flows BACKWARDS through the second pump right?
In much the same fashion if one pump dies, it'll send fuel backwards out the dead pump, leaning your engine out?
Very VERY bad idea for a fuel setup...
Get ONE main pump. If it dies, at least the engine just turns off... It doesn't lean out.
Ive seen this one before...
Fuel temperature. How hot are your pumps when they get noisy. Running two pumps circulates a lot of fuel and its all getting nicely heated up by cooling your fuel rail down. Check them when they are noisy. Warm is ok, but leaning towards hot certainly isnt. They start to cavitate as they boil the fuel internally. Then the sound like they are pumping gravel. The solution is to put a fuel cooler (small tranny cooler) on your return line at the back of the car. It makes your tune far more stable as well and lowers your over all fuel temps and minimises temp variations.
Also, if its an R33 Vspec or R34 gtr there is a fuel pump control module mounted under the drivers side parcel tray. There are two signal wires sent from the ECU that change the factory pump from low speed operation to high speed operation. This happens automatically at a specific load point around 3500-4000 rpm from memory. If you want to run one pump constantly, and switch in a second pump under high load, this is where you pickup the relay activation signal from. That combined with a 1 way valve on the switched pump would do the job just fine.
I see MBS206's point about a lean out, but I believe that a car tuned to the point where it has a need for twin 600hp pumps would also have a decent AFR system as well. Plus if you know your car you can feel when its running lean and if you have 1/2 a brain you dont try and drive through the "flat spot" that it feels like. You get off the throttle and make a few checks.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
