Item 1 : Sabelt 3 inch 4 point Harness
Condition : Brand New in Box with all the installation manuals and bolts
Price : $450 + Delivery
Item 2 : 4 Kumho KU-36 tyres
Condition : Brand New and un-fitted.
Size : 17 x 45 x 235
Price : $600 Firm
Lots of good reviews for this tyre. They are comparable with the RE-01r. Prefer local buyer. Interstate buyers will need to arrange for their own freight.
Items are located in Melbourne.
Please PM me if you have other questions, thanks.
Sabelts are brand new and UNused. If i'm not wrong, they are FIA approved too unless someone wishes to clarify this.
Well i noticed sebastian loeb uses them today so id say so.
keen, but too pricey for me atm.
That's the cost of having a good quality harness compared to the crap ones out there. For the crappy harnesses, after using them for a while, your body will start slipping under the harness. A brand new GENUINE Takata harness is about $700 at the moment. Sabelt is much less and they are used by WRC teams as well as some F1 teams :)
Hey mate,
just registering interest in a pair of the tyres.
if the previous buyer falls through and you're willing to split them up, i'll grab a pair.
pm me
thanks,
greg-
Hi Greg, thanks for the interest. Unfortunately, even if the sale falls through, i won't be separating the set. Thanks!
I wonder is this thing street legal Ben?
What do you mean if it is street legal?
I don't think you would using them on the streets when you have your own seat belt unless your car doesn't come with one.
If you have it installed in your car, you can always place it behind the passenger seat at the back. During track days, you can strap them on.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
