Hi man
I am able help with a peddel box that is in perfect shape and has just come out of my 32 gtr.how dose 50.00 plus 20.00 postage sound.
I would get it off to you monday so you would get before week end
stuart
Hi man
THat isn't as easy as it may be seeing it is still in the car and bolted up to fire wall.
this car was driving and performing up untill 8 weeks ago.it is fine.
stuart
Hi mate
The assembly isn,t out of the car yet,as this car was driving around 8 weeks ago.
I will asure you it isn't damaged [bent or cracked].
I can take a pic but i dont recon you will see much.until it remove.
stuart
fair enough most likely one to fit would be out of a gtr I suppose since the gts4 has the same 4wd drivetrain engine excluded., was just that the dealer said there was two types. Pm me your bank details and I'll transfer the money, I'm in canberra btw, post code 2615. what year 31 gtr is it out of.
Funnily enough mine snapped in two places lol.
Hi man
It is out of a r32 gtr not r31 gtr as they were never made.
the clutch pedel box is out of my r32 gtr please confirm with me that this is what u want and i will remove tomorrow night and send to you tuesday.
westpac s.willcock
bsb 037012
acc 163404
stuart
mobile 0409135950
Hi chris
I have removed clutch pedel box and i have just checked account nothing as yet.
I will look later and if there i will send tomorrow morning.
Mate i need your address detailes
stuart
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
