I still dont understand the fascination with stupendous amounts of camber and the oversized rubbers that hit the guards
somehow its cool to have your bowels forced into your lungs when u drive around with shithouse offsets and low profile rubbers
ffs we're in australia here, kiss your $2000 rubbers goodbye every 6 months with that much camber and the potholes
-D
you need to change tyre shops then
well i figure, why by shit rubber if u drive a decent car? Im running stock 16's and my toyo t1r's come in around $880 odd for the rubbers
when i factor in the price increase for 18" rubbers >if< i was gonna get 18's, and the rubbers are pretty decent like the goodyear eagle f1 assymetric, it comes out to damn near $2k sure u can shop around but still, you go up two inches in rim diameter and be paying like twice as much
-D
i bought 18inch bridgestone potenza's 80% tread in top condition a number of times for $180 each. Very good tyres and they last ages from Used Tyre mart. I could afford to buy brand spankin new tyres but I dont see the point in spending $2000 for tyres that just wear out anyway.
Edited by Ryanrb25
nice and cheap if u got the connections but most of us peons have to go to a tyre place and have them balanced, fitted and aligned... not all of us are mechanics
-D
who ever is paying 2k for 18" tyres that arent high end R compound tyres or something is getting raped.
ur getting raped too lol
but that comes complementary with every purchase at used tyre mart.
lol nissdik, I wondered how long it would be before the dribble started again......having said that, I don't mind a bit of sarcasm from mates .
You must be a very little man with a 10ft tall keyboard......can't wait to get acquainted!
-D
I got Brand spanking new Bridgestone Potenza RE001 rubber for my line for....$209 fitted and balanced
235/45/R17's for $209 and no you dont need connections to get a bargain, and i rate the RE001 very very highly as to the amount of grip they offer on these Adelaide roads, very impressed with the tyre performance.....and I am no mechanic either
So $180 for 18's with 80% tread left sounds fairly decent price too ryan
Here's some NS prices for tyres, oh and they're semi's;
KU36
205/50/15 $151.00
215/45/16 $133.00 Nil Stock
225/50/16 $155.00
215/45/17 $161.00 Nil Stock
225/45/17 $194.00
235/45/17 $164.00
245/40/17 $215.00
245/45/17 $220.00
255/40/17 $224.00
275/40/17 $250.00
285/40/17 $275.00
315/35/17 $250.00 Order In Only
225/40/18 $233.00
225/45/18 $235.00
235/40/18 $224.00 Nil Stock
245/35/18 $206.00
245/40/18 $254.00
265/35/18 $224.00
275/35/18 $277.00
285/35/19 $269.00
http://www.nissansilvia.com/forums/index.p...howtopic=390155
Edited by D_Stirls
this awesome thread is going moderately average
cant find the pic but a days of thunder"his way my way" comes to mind :)
and damo if that ferrari pic is real holy f40 thats crazy. ive only eva seen 1 in real life
MORE AWESOME DEBATE WHICH CAME FIRST CHICKEN OR THE EGG
Edited by Inline 6
yep, very little, that's me :)
Dayummmmmm I wouldnt mind a set of in 235/45/17 for $164.00..... where'd my birthday money go... oh wait thats right - alcohol! :)
and just to keep this post on topic:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
