wangan midnight movie making - devil z tuffness :) take the bumper off though you panzy. needs black wing n wheel arches also
where u find most abandoned twin turbo s30's
if the game looked this real would be sweet :D
Edited by Inline 6
actually it is a gts, note the air con and stereo are around the wrong way. f ing lot of effort gone into making it look like a gtr though
sorry turning this into wasteland apoligies
Dunno, its at absolute minimum a GTS4 because the floor in the drivers footwell isnt like mine - the 4WD ones have a bulge there...
Also, the climate control is piss easy to move, mine used to be at the top where the gauge trio is in GTR's, but its now on the very bottom to make way for a LCD screen - point being its pretty much take out and re-mount. I rekon it is a GTR, just with an aftermarket sunroof...
I did have a photo to upload, but I'm getting mega dropouts today...
Edit: R32's represent!
no he was talking about hostiles n1 wing :)
technically its the same thing right? How about some grey scale retro presentation on the 32 pic :D
was quite pleased with those pics of the 32s as trying to organise a 32 only cruise was met with abuse
dions car he can do what he likes with it, let him be. he aint put a gtr badge on it yet so cut him some slack :)
Edited by Inline 6
no he was talking about hostiles n1 wing.
technically its the same thing right? How about some grey scale retro presentation on the 32 pic :)
For someone that is SAU's "mr.sarcastic" you really blew that joke out of context. It was an ongoing joke on Facebook.
its not all i blew mate :D happy smiles now inserted
who gave me that title i do not accept it :) this is a serious man
less chat more z, this is how i want mine, maybe smaller flairs n blue with black
http://speedhunters.com/archive/2008/06/17...attle-s30z.aspx
this black 1 looks tuff also, think i like the red 1 better though
http://speedhunters.com/archive/2008/05/23...alth-240zg.aspx
Edited by Inline 6
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
