Yes SLOWLY.
Got to stop being so damn pedantic.
That's where it finished today had an issue with the main caps so i'll pick it up again tomorrow. The bottom end WILL BE FINISHED TOMORROW.
My Assembly room; The Cone of Power
Edited by D_Stirls
Yes SLOWLY.
ur like dexter.... but with engines
damo. .. that is funny on so many levels (well... 2 levels)
acetone on one side of the plastic wall , fire extinguisher on the other..hmmmmm
in case of fire please wait for the exit to melt before extinguishing
or do you just like to sniff the fumes without loosing a drop..lol
and when your done you can give the stuff to the local meth lab to help reduce his setup costs..lol
Edited by sapphiregraphics
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
