yeah my chrome fail comment was a little broad
As long as its not a genuine m3, has altezza tail lights but no engine mods and 3 tv's per vehicle occupant, those rims are acceptable..
their those CCW wheels yeah? they look damn good and are pretty cheap too
Last time I priced up a set of CCW classics (when I still have the Celly), I was looking at a little over $6k shipped...
really? on theyre site it says theyre $2500 a set. how much was the shipping?
edit: even if you went the powder coat and arp stud route youd only be adding around $850
Shipping was was an astronomical amount. Somewhere around the $1500 mark. 22lbs a wheel, in customs sizes and specs with upgraded hardware. Though it 'starting at $2500' 3 years ago when I was looking at them.
  • 1 month later...
I am getting so f**king excited about this car and everything it represents. Starting weight of 1180kg for the base model, and 1240kg for the range topper, with the same power as the last locally delivered S15, and all with fuel economy good enough to make it suitable for daily duties... Yeah, I'm pretty keen.
Has been confirmed by Toyota for sale in Australia, and Subaru won't be far behind when they figure out how they're going to market it without their symmetrical all wheel drive safe tag, Tom's and TRD are already looking at warmed up versions, Toyota themselves want owners to modify and personalise theirs. So refreshing.
Non turbo 2.0 litre boxer direct engine with 147kw, STi BRZ may be turbo, 6 speed manual, or 6 speed paddle shifted auto, LSD, rear wheel drive, and all in a 1200kg package.
As for price, Toyota is aiming for the low $30k range.
Yeah according to Speedhunters, they have already released info to the Nippon Aftermarket Committee so manufacturers and tuners can start production of aftermarket parts! New car owners will have the option to change out the suspension and add aero mods on day 1 of ownership!
THIS!!! What a revolution. Best thing a car company has done in a long time.
Cant believe Nissan tried their darndest to exclude the GTR from the aftermarket scene, why not encourage personalisation and stimulate the aftermarket economy!
In short, the car gives me a hard on. Looks wise, not so much, but the potential.... huge.
I'm a big fan of the way they look.
That second photo I posted shows a couple more or less confirmed options for when it goes on sale in North America/Europe, fixed back seats, harnesses, and TRD gauges.
It's something I would never have expected from Toyota, openly embracing the aftermarket. I imagine the options list will be pretty immense by the time it hits dealer floors here.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
