Wow those look like a pretty good package! My only concern holding me back from buying any of these big screened units is the issue that Scott has had just above, due to the size of the screen the light output might get a bit irritating at night. Is there any way to adjust the brightness or temporarily turn off the screen only?
  • Replies 79
It says in the product description:
Display Adjustment (Brightness, Contrast, Color Arbitrarily Settings)
I'm not too technical on the wiring side of things but the 'illumination' wire.. does that connect to the dash lights so it dims when you turn the lights on?
I've got an Eonon unit installed in my commonwhore which cost bugger all ($200) and it does everything except make my breakfast!
Doesn't have GPS or BT but it plays nearly every format known and has USB support which I use my 8GB thumbdrive with. :D
Looks like this:
Guys,
Most of the units on ebay are eonon, i had one a 2-DIN DVD touchscreen
lasted like 8/9 months was a good buy for 330 delivered to my house.
I figured it paid for itself over that time, it was a good cheap alternative at the time.
In saying that it did die last week and wiring was a bit of a pain standard wiring cant supply enough power.
result?? i ran a seperate power wire with a secondary fuse of the battery for any spikes in power.
Any questions on the units just pm me, ive installed a few of the different models available from ebay.
Thanks Rob, might have to hit you up for some help if I get stuck installing this myself if you don't mind!
I can't seem to find any reviews anywhere for the other unit.
All I've managed to find out is it's made by Hoatoa (www.hoatoa.com) and it's the HT-9000i model.
I'll probably give it a shot anyway.
  • 3 weeks later...
Hey Pat
Did you have trouble fitting the unit to the space of the dash surround?
Seems the unit is just a tad bigger and I might have to file back the dash piece so that it can sit properly around the screen..
Hey Pat
yeah i had to file off only about 1-2mm off each side, took a whole of 15 mins :happy: other than that it fit well, but ya cant get the surround on because the climate control is too close to it
Awesome! Thought it was just my inability to put it in properly haha.
I'm a little confused how to wire the rear camera and tv with the lack of instructions it came with though..
Did you have to run the camera off a relay?
And I thought I hooked the tv up properly but it keeps saying about the safety when I try to click on it..?
Any help plz?
Thanks!
Right now those are the only two things not hooked up properly, but I'm loving the unit anyway!
GPS works a treat :down:
Any help plz?
Thanks!
GPS works a treat :P
you have to ground the parking brake wire! to access tv and dvd. its meant to only display movies/tv when the hand brake is up! but its easier to bypass :down:
and the rear camera is meant to be hooked up to the gearbox/reverse lights... it turns on automatically when you put the car into reverse. I didn't bother with a reversing camera so i can't be of any more help on where exactly to hook it up to. You could bo a test by powering it up and grounding the reverse wire and see if it changes automaticaly to the camera input
Thanks so much!
I'll give it a shot in the coming days, for now the wiring has all been laid and I put the interior back together just so I can drive around for the time being.. I'll hopefully be able to give a proper review once it's all connected properly :banana:
just got one of these of ebay
If you want to get it dirt cheap, search around for a week or so, find out when they sell the cheapest, which would be later at night (10PM+) or earlier in the morning.
Some have a buy it now price of around $400 and can be bought in an auction for around $200-$300, mine had a buy it now price of $380 and with postage it was $298 after auction
The only complaint i would make is its a little slow to load, if i my dongle into the usb slot it takes 10 sec or so before it registers and begins to play But not to bad, GPS seams to be accurate although it cant find a location if you more than 10 meters from a road. eg in a shopping centre car park (on the roof)
also mine didnt come with a tv antenna so thats going to be an extra $30-$40 depending on type and brand
Any sugestions on which type of tv antenna to get?
  • 3 weeks later...
Just an update, the unit is working perfectly fine.
I finally found time to ground the parking wire so the TV/DVD function works. Picture quality is brilliant for video/DVD although I think I'll try to find an alternative to the small antenna it came with for TV use.
Reverse camera is handy since the wing is restricting view out of the rear, it lets me see if there's any objects behind me, so long as I don't start relying on it then it's a good addition to have :)
It also has an outline of distance overlayed over the rear camera display so you can judge parking manouveres.
I went to Gary's Car Radio and inquired about an alternative antenna option.
They recommended and use on their own cars, an in bumper antenna which sits behind the front AND rear bumper so it's not visible, but the best he could do is $270.
Also there is the option of a windshield film antenna for $180 which he said works very well also.
I saw online that the windshield film antenna type can be had for $40-50 but I'm not sure how that would compare in it's ability to pick up signal to the $180 one he quoted me. Maybe it's the same :P
I got the reverse camera hooked up.. so far I'm just going to leave the surrounding dash piece off while I try to source another one to modify a little to make it fit around this unit.
Works pretty well, very clear, night time isn't a problem either.
Edited by UnCo
How did you do this? Constant power or ACC power? I'd guess it's the ACC power because the constant just holds the memory? I think!
I'm looking at getting one of these for our Elgrand, but with the digital TV feature too. But going through the people who sell to the ebay sellers who sell to you. May as well cut out the ebay link, still PayPal it and have it freighted to my door.
Cheers, Greg.
I purchased this second one as well which has digital TV
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=270439423461
It's very similar to the first one I bought with only slight differences such as
- In GPS mode if you adjust the volume, it adjusts the music volume rather than the voice commands volume (I think this is better because most of the time I just drive around with the GPS map showing but with no set destination, so I want to be able to adjust the volume without temporarily going to radio/cd mode then back to the map.
- It seems to play music off the iPhone via bluetooth without needing to plug the ipod connector in.
Only thing is, when the ipod connector is plugged in, the music doesn't go through to the unit but plays out of the iPhone speaker.
Just a few tiny things like that.
I'm not as big of a fan of the GUI on this compared to the first one I got either.
All in all it still does what I bought these to do, so I'm very happy with it!
a few of my mates had these 2 din types and the only recurrent problem they experienced was the flip-down mechanism, it stuffed up after sometime, doesnt open n shut properly. but otherwise they aint a bad piece of kit, considering price. looks good.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
