Hey guys,
I have some stickers for sale here
HKS - Black - in 35mm high and 60mm high
Nismo Italic writing - Black - in 30mm, 50mm, 70mm, 100mm and 120mm high
Nismo Italic writing - White - in 120mm high
Nismo Rounded writing - White with red - 10mm and 15mm high
Nismo Rounded writing - Black with red - 10mm and 15mm high
Apex'i - Black - in 35mm high and 60mm high
i have about 6 of each in each size
$4 for 10mm, 15mm, 35mm stickers
$6 for 50mm, 65mm, 70mm stickers
$8 for 100mm and 120mm stickers
+postage or pickup
https://www.sau.com.au/forums/topic/272668-stickers-for-sale-hks-nismo-apexi/
  • 4 weeks later...
  • 1 month later...
Ok, i found a few more, so here is an updated list of what i've got and the prices
Nismo Italic - Black 30x60mm
Nismo Italic - Black 50x100mm
Nismo Italic - Black 70x140mm
Nismo Italic - Black 100x200mm
Nismo Italic - Black/White 130x260mm
Nismo Rounded - Black/White with red 10x70mm
Nismo Rounded - Black/White with red 15x90mm
Greddy - Black/White - 35x285mm
Greddy - Black/White - 60x500mm
Trust - Black/White - 35x295mm
Trust - Black/White - 60x500mm
HKS - Black - 35x75mm
HKS - Metallic Silver - 60x130mm
HKS - Black - 65x140mm
Apex'i - Black - 35x250mm
Apex'i - Black/Metallic Silver - 60x420mm
$4 for 10mm - 35mm stickers
$6 for 50mm - 70mm stickers
$8 for 100mm + stickers unless otherwise specified
+$1 postage
(will post at my own expense if buying 4 or more) Various stickers
post-40562-1251111142_thumb.jpg post-40562-1251111177_thumb.jpg post-40562-1251111201_thumb.jpg
Are these decals or stickers?
Well there isn't a great deal of difference, but if you look at decals as 'cut from self adhesive vinyl' and stickers as 'cut from paper with a sticky backing' then they are Decals.
i'll take an apexi sticker. pm bank details and postage/
What size bud?
you have pm
do the 60mm HKS ones suit a black car? is the while the outline or is it black sticker?
Hey,
The sticker itself is black, the white you see in the image is just the backing paper, i also have white ones in those sizes, i mustn't have written white in there.
Whether itll suit a black car will be a personal preference thing, where did you want to stick it?
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
