Hey guys,
My clutch is playing up, all the feel is at the bottom like 1-2cm, and the top is all squishy
It used to be feel/pressure up to about the middle
Im not sure what clutch is in it as i havent pulled it appart,
was seeing if youz might know what the problem might be?
Thanks heaps :)
Edited by MYCEF3
https://www.sau.com.au/forums/topic/272940-need-help-clutch/
haha no!
Was seeing if it was a common problem (not with the clutch plate it self)
But if it is the start of the clutch goin i can replace it
Iv never destroyed a clutch, iv got cars then placed a new clutch straight away (depending)
haha no!
lol i think this might be ur problem:
!! Kick the Clutch 'n' Slide !!
i remember shaun at boostworx, after he'd put my exedy in, im like yeh so how much do u think it had left in it? hes like probably 95% worn, with a lot of clutch kicking marks haha
yea iv heard extreme r over-rated (not as good as it is put out 2 be)
So how long do exedy last stewy (daily use and now and again on the track)
and madaz is the NPC with AM Performance?
Also how long do they last (same question as above)
exedy through kudos.
personally i wouldnt bother with stuff like extreme.
I have an Extreme extra heavy duty single plate and my car is making over 300rwkw's. I have been known to do the odd 2nd gear smoke show in second gear (RWD) and plenty of 4wd launches and its still going strong and its been in the car for a couple of years.
Yeah, see urs has lasted ages which is good!
Iv had mates not trashing it but it hasnt lasted no wear near as long as that!
Is there any write up wiv all the clutches and pros cons, anyone has come by?
no NPC isn't with AM performance but he does have a NPC clutch same with a few other guys on the forums ive heard no complaints so far haven't yet tried one
not sure how long they will last depends on if your ride the clutch
Where to mention SAU then?
No dont ride clutch... Hate the sound of it :down:
couldnt tell u how long they last as mines not done yet lol, ive had mine for a few years now and has seen many days of drift, including a lot of 3rd gear clutch kicking.
it very rarely slips, ive had it slip on me maybe once or twice at the track, and that was after a lot of brutal 3rd gear punishment.
mines a heavy duty cushioned button, regretting i didnt go the un-cushioned one now as it doesnt quite deliver the same punch when clutch kicking, but the cushioned is much better for daily driving.
check the brake/clutch fluid level
the fluid can appear to be full when looking at it from the outside but it maybe just dried and stuck to the inside giving the appearance its full when its empty. of course if thats empty then begins the search for what is causing it to leak. possibly the clutch slave :D time will tell
if that aint the prob then try to lay off performing your sig qoute :D
Edited by Inline 6
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
