Qld Suck!
Yes it can be adjusted so that it does not ruin the party in Nistune. But you must have the sensor connected or the ECU will be bitchier than a teenage daughter.
Agreed, wooden ramps can’t go wrong. Or buy low profile ramps ie. gktech
By RB25inside · Posted
