$300 for the GTR bonent
$80 for the GTR rear wing
$60 for the boot
$100 for the rear window
$80 for the rear tail lights
$90 for the head lights
$80 for all the door trims
$80 for all the doors
$30 for the coilpacks
$1100 for the rb20 and wiring
$250 for lsd diff
$100 for diff cradle
$100 for front and rear strut brace
  • Replies 47
  • 4 weeks later...
Hi guys and girls i am wrecking my r32 4 door all panles are in primer have pics have paint as well make a offer on the parts but need $500 for the paint
hi mate i'm chasing a few r32 parts
-stock steering wheel
-radio brackets
-passenger side window switch
-stock speaker covers
-centre console lid
have cash ready to spend let me know what youve got
and how much you want for it etc ill pay postage thanks mate
best way to contact is by email: [email protected]
do you still have the headlights available?
im after the LHS headlight. is it a bugeye/ projector type? does it take h3 bulbs? will you post to nsw?
cheers, tushar
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
