Hey there, Yeh you can run your highflow turbo with your stock ecu but beware.... once your boost goes past 12psi..... you will hit R&R and therefore you will require your spark plugs to be gapped at 0.8mm and will start miss firing past 3-4rpm.... it will miss..
I dont think RnR has anything to do with the spark plugs, its the AFM reaching its limit is it not
  • Replies 43
R&R, stands for rich and retard. Nissan programmed the engine mapping so that when the standard airflow pattern is exceeded by much then the ECU dumps in more fuel and retards the ignition timing. This is to protect the engine as the only reason for higher than normal airflow is something is wrong or someone has fiddled with the engine, either way Nissan has taken steps to protect the engine from damage. Sticking on a high flow turbo is most definitely fiddling with the engine so, without tuning, you can expect piss poor fuel economy, oil contaminated with fuel and an incurrable misfire from the retarded ignition timing.
There is plenty written on the subject of R&R, a lot of it by me, so I strongly suggest that you try a search.
Cheers
Gary
HKS GTRS kits are worth considering now the Aus/Yen is decent. Many highflows use a similar (or the same) core as the GTRS - but none will get results quite as good due to housing constraints. Rated at 290kw (flywheel) - so around 230rwkw at just under 1bar.
Plus a GTRS kits is 100% new parts and you get to keep your old turbo.
I'm looking into turbo replacements as well, but considering the total all up cost would be $4800 it's hard to justify.
480cc injectors ~ $450
Z32 AFM ~ $250
Power FC ~ 1200
HKS GTRS ~ $2900
Total = $4800.
Z32 AFM ~ $250
Power FC ~ 1200
HKS GTRS ~ $2900
Total = $4800.
That $4800 equals solid reliable quality performance. It really is worth it to do it right the first time than doing it cheap and having stuff go wrong or being unsatisfied in the end and spending more money for quality upgrades you should have done in the first place.
4800 isn't very expensive anyway... Your getting a 250rwkw ish performance machine for around 25k in total.
Thats just my opinion though :P
  • 5 months later...
Hey there- What the bloody hell is R+R?? i run 14psi on my stock turbo (rb25) and runs kick ass!! lol
I have my plugs gapped at 0.5mm and just have FMIC, HKS POD, 3inch catback and dont have the missing prob-
I only recently got the catback done too and didnt have the issue before-
so just curious, Am i just lucky??
Yep you are one in a million take it to the strip and run a ten already. I'd be surprised if the standard dump pipe could even flow 14psi.. as well as the turbo.. among other things...
I ran my highflow on standard ecu for about a year driving around on it fine. It had a bit of a flat spot up the top but apart from that the ecu seemed to want to play ball.
That said i would much rather drive a car with an ecu (power fc/microtech) with a standard turbo than a highflow and stock ecu having had both now.
The best thing about highflow turbos if you go that path is there is always people wanting to buy them... coz they're cheap and effective and produce quite good results. So down the track if you want to go to a bigger turbo then you should be able to sell the highflow for near what you bought it for provided it's in same condition.
you probly THINK it runs kick ass because your boosting '14psi bro'. But its probly not. Its just fact.
are you serious? the stock dump will flow 14 psi easy, my boost controller decided to give up one day and my stock turbo was hitting 25psi for a good 3-4 runs in 3rd, makes a different noise up at that level haha.
Ouch, said the Head gasket
It certainly runs alot faster when its on 14psi then any other- you dont have to be clever to figure that out-
it was a little bumpy above 13 at first, then i gutted the cat- then it went fine- now with the 3inch catback its running even better! :)
The Dump can handle whatever you throw at it.. i couldnt imagine a stock turbo hitten 25psi without a bang but it does fine with just 14 psi now-
Im going to4e high mount with ext w/gate soon enough, that should prove to be interesting, str8 3inch from turbo to canon... mmm... lol
  • 1 month later...
sori for digging up an old thread.
ive settled on a hypergear highflow and nistune in the new year.
r33 series one what do stock inj max out at?
i've been told various things, tuner told me 260hp atw it maxes out at.
and that injectors max out before the afm does.
does that sound about right?
i jus don't want to have to overcapitalise injectors if i don't have to.
i surfed through the rb25turbo upgrade thread and 33's seem to make easy 220rwkw on stock inj. without an fpr.
anyone had much gains with a nistune on a totally stock r33 (exhaust and fmic, 10psi)?
it all depends. i maxxed myne at 185rwkw on a very restrictive setup with a safe tune, other people have pushed them to over 250rwkw. to make the most of the highflow safely you'll need some bigger ones tho.
Edited by JonnoHR31
it seems that to make a high flow upgrade worthwhile, i have to upgrade injectors.
i have tried searching for hours,
but if i nistuned my car as it is, (fmic, 3.5 inch turbo back. 10psi, bosch 040, bcpres7)
would there be much gains?
i just want to justify $1000 down the drain.
i was told to source 550 cc inj
are there any direct bolt ups from other nissans that are available secondhand?
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
