HI guys
i have a full set of Apexi N! coilovers for sale nice condition no leaks they were on a S1 stagea so will fit S2 as well but Auto car
fronts have Apexi springs rears are HKS Springs
when new they are around the $2400
looking for $1200 but open to serious offers
PM me if interested
https://www.sau.com.au/forums/topic/273616-n1-apex1-coilovers/
no sorry no pics on the car but it was low top of the tyres were just under the lip of the guard all round they were pulled off the car the day i imported it i could not get it in my drive
got a pic of these on the car ? just for reference thanks :)
