yeah there stiff low shocks that have the sweetest performance. Had no problems and i have never ever had the car even make a chirp from the tires around the corners let alone a slip.
performance 9\10
Comfort 4\10 ...... yeah you gota sacrifice some stuff somewhere to make up for other stuff
  • Replies 41
the shocks say KYB on front and rar but the springs i think are 5zigens. Bilsteins, such expensive but sweet ass suspention.
i was looking into getting ISC, HSD or Nismo.
how are the ISC for handling?
the KYBs are amazing, can take corners at 180 but its just the worst to be comfortable in.
hey guys,
just giving ya an update, well ive bought some kyb excel g front and rears shocks, the rears fit perfectly but today when me and my mate tried to put them on the front they didnt fit... there just slightly different, cause of the awd setup i assume, so now im in abit of a pickle, so all of you guys that have aftermarket shocks on the front of ur gts4's, could you please tell me the exact brand and model of ur shocks? lol, im so tired of messing with the car haha.
cheers guys, any help would be awesome
the actual shock is about an inch too long and cause of that the bumb stops dont fit and the screw thread on the end sticks up too far into the engine bay and the bonnet doesnt shut lol, basically lol. where ur's any special type of kyb shock?
I HAVE THE CAMERA!! :P
i wont need to take stupid phone pictures. What do you want me to take pictures of?
I can get under the car only fractionally as im buying new rims and have a 15" space saver with 3 17" rims everywhere else so its on a lean at the front.
Give me a heads up of what pics yours after?
well what i really wanted to know was just what brand and model ur front shocks are, they seem to be the ones causing all the trouble for me lol, cause i have some kyb excel g shocks right now that dont fit lol, i think there for a gtst tho, the backs fit but the front dont lol.
cheers mate
cheers mate
i don't get it the KYB website says its gts-t suspention R33, 2WD Turbo Coupe Incl. 4WS (Note: Rear Lower Eyering Mount Type) Excl. GTR
that 'Note: Rear Lower Eyering Mount Type' is for us because its suppose to be gts-t.
Stagea's have gts-t suspension........
I have pictures
The only other thing i can do is try get behind the space saver and read for a logo on the other side. Its to dirty to see anything on the side i had to get pics of.
I had to take pictures of the dirty side of my car as i have a space saver on the other side because i destroyed my rim..... Getting new ones but :(
anyways i need to get the CV changed its covered in grease everywhere.
there aftermarket
Its the driver side that's really dirty and everything is covered in grease and dust over that because i haven't gotten the CV fixed. I cant get a good picture on the other side which is clean
I posted picture of my fronts before when i didn't have the space saver on. :)
Hey mate, Here's some info Sydneykid gave me when I was trying to find suspension for my old R33 GTS4.
"What you need is R33GTR front shocks and springs to handle the extra weight of the 4wd system and R33GTST rear shocks and springs to suite the mounting system. I have not seen a decent off the shelf spring and shock set (all 4) that is specifically designed for an R33GTS4
The Group Buy kit for the R33GTS4 has the front and rear Bilstein shock valving matched to the springs, bars and to each other. I spent quite a bit of time getting the items matched up. It is definitely a technically superior system. The ride/handling balance is very good, just a bit sporty but not at all harsh."
That was back in 2005, not sure if his Bilstein suspension kits are still available but send him a message and ask him or just if you need any more info about suspension he's a very helpful and knowledgable member here.
:) i didnt know.
It all makes sense now :D
Thats really annoying because there no way to get anything second hand without buying gts-t and then GTR stuff and your left with two sets of shocks ......
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
