i guess so.. give it a try! If it clears everything like the firwall and gearbox etc etc i dont see why chopping it back wouldnt work.
You wont need a new flange if you dont want. Chop it back tight against the flange, then cut off the required amount and re use it.
I dont know how much stainless flanges go for, but if you have to buy a new one, then pay someone to do the job, and install the pipe you probly would have saved $ buying an R33 one. They are only like $250 from JJR!
Any competent exhaust shop could cut the ~30cm or so from the existing exhaust and re-weld the flange so it all mates up.
I had the reverse done when I turbo-charged my old R34, they welded on a 30cm extension so the flange butted up to an R33 dump-pipe which was too short.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
