Hi all,
Can a bosch 044 fuel pump directly replace the stock intank fuel pump (in an R34 GT-R) or are there other fittings/modifications that need to be done to the 044 in order to successfully mount them in the fuel tank?
Cheers,
Edited by xanavinismo
https://www.sau.com.au/forums/topic/273877-bosch-044-fuel-pump/
Just remember if you replace the intank fuel hoses use Flouroelastomer outer hose. Regular efi will go to shit.
I am running an 044 intank in my 32 gtr, been great so far. You may also find these fittings usefull it's what I used:
Here
It allows you to come out at 90 from the pump outlet so you don't foul against the side of the tank. Has a pick-up as well. I looked everywhere for those fittings even Enzed couldn't do it, thread pitch on the 044's is not the norm which makes it hard.
Edited by James_03
Thanks a bunch for all of your replies guys. Although having read whats actually involved, I might end up getting a Nismo fuel pump instead because to my understanding, they are a direct replacement for the factory intank fuel pump and no modifying is required on R34 GT-R's?
Cheers,
ive got one in my 34.....there is no cradle on the 34.....its got a big rubber sleeve and clamp that holds the pump...its not quite large enough for the 44 pump....just use a hose clamp to hold it to the point where the original clamp goes....
you will also need a fitting to go in the intake to convert the pump to a barb so you can use the original hose and pick up filter...and one on the outlet to convert to barb....it works out it just runs straight in line as the original pump does....id say its the most simple gtr's to fit this pump to
Sorry to digress....is anyone having any surging issues with the intank 044 on track (circuit) days when cornering? If so what was your fuel level when this was occuring? I guess what I'm getting at - is it necessary to go to a surge tank setup for a bit of (safe) fun on the circuit?
It sounds like you are enjoying some of the oh so common overheating and cavitating problems that 044's do. A fuel cooler is meant to help quite dramatically, however it hasnt worked in my application.
It's something that I'm contemplating but just curious as to the pro's and con's of in-tank vs external vs external with surge tank.
If you mount in-tank do any problems exist as this would be the neatest way......but was wondering whether a dedicated surge tank was required for the odd treck to the circuit where G forces would be higher?
I have an s15 and can run my fuel down until the fuel light comes on without any fuel pickup issues at the circuit. Was thinking of upgrading my fuel pump (currently Nismo) to an 044 when I make the switch to E85. But was curious as to the best way to go.
I've nearly rear ended a few VR and VS Commodores at the circuit where they have fuel surge issues mid corner resulting in temporary engine shut down at the most inconvenient of places.
Here's a few setups I came accross on another forum:
http://www.freshalloy.com/forums/showthrea...fuel+pump+setup
Edited by juggernaut1
if you already have the nismo keep that, it flows the same if not more than a 044 assuming you aren't runny silly rail pressures.
I thought the Nismo was 4.1 litres/min or 246 litres/hour.................. vs the 044 at 300 litres/hour....no?
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
