Hey guys i recently bought a v35 350gt and i am going to be changing the engine oil and transmission fluid, does anyone know what the best one to use for the engine is and also what the best one for a manual tranny would be, thanks guys.
Arnie, see below in my sig for a link to the V35 section.
In all honesty if it is a stock car, with low kays and still quite new as most V35's are, mate i would just use what the manual specifys.
It also depends on your usage. If you are the type that will cain the car daily and be very hard on it, then a top of the line oil is essential. If it's just a daily driver, then some grade 5 oils might be overkill.
yup i agree with this response.... :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
