Im new here :)
Right now I have a GTS25 NA stock and I want to buy a Kakimoto exhaust system because of it's amazing but not excessively loud sound but which one is the best to buy
-Full mega N1
-regu 06 (i think)
and if I purchased one of these exhaust systems, how much of a power will I gain?
Thanks
https://www.sau.com.au/forums/topic/274338-kakimoto-exhausts/
  • Replies 40
kakimoto's are great. I would always recommend them for NA's but you have to remember its going to said noticeably different to a turbo skyline. The regu 06 will drone from a NA because its a cannon without the hotdogs etc etc. If you get the kakimoto R, part NO. (NS310) 70mm Pipe - 115mm Tail would be the best performance wise for a NA.
its up to you
cannon
muffler
its up to you
cannon
muffler
Thanks mate, any idea what kind of kw i would be gaining from the kakimoto R?
Hannibalk1ng would be right there. Extractors would compliment the exhaust system. The main difference would be that buying a muffler would allow you to have more power through lower range (its better for street basically).
Getting that cannon catback Kakimoto make means the pipe is designed for turbo skylines so it will very droney and performance lacking on the street and even on the track you would have to reach the red line for it to feel different performance wise to a stock exhaust. Its designed for a turbo not NA, so unless its on the track at 6000-7000rpm it wont be able to be even as good as a stocker.
Thats why i would just get the muffler. Its like the stock design but functions better than it so its going to be better than it was before anyway.
Thanks for everything, I was just curious about the power gain but I dont need it. I just prefer the sound of the exhaust. The power is just a bonus for me.
Yeah I dont want much drone (a little is ok) so wat type of exhaust limits drone?
Edited by mick2nv
do not get a kakimoto exhaust i have one
when people get in the car for the first time they cannot believe how loud it is, ive never had someone in my car who hasnt made a comment about the exhaust.
spend the money at a exhaust shop and get a custom one made to suit your car
you will spend less, have a better note and a power increase
is it a cannon from Kakimoto or Kakimoto R??
the Kakimoto R model is quite and it can be loud when you but your foot flat but at least its not a loud drone as well......
Best best get one made up from any exhaust place. 2.5inch all the way and a cannon. probs looking at $ 350 installed.
but expect a drone while on the freeway doing 100kms
Thanks I'll take your advice and get one custom made.
Soon hopefully
LOL, the Full Mega N1 Hyper 2000 = Excessively loud, stock R34 with it was 113dB :P
It sounded tough though, on gearchanges it would "bark" and it scared small children. Downside was that after a good drive your ears would be ringing (true story)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
