Im new here :)
Right now I have a GTS25 NA stock and I want to buy a Kakimoto exhaust system because of it's amazing but not excessively loud sound but which one is the best to buy
-Full mega N1
-regu 06 (i think)
and if I purchased one of these exhaust systems, how much of a power will I gain?
Thanks
https://www.sau.com.au/forums/topic/274338-kakimoto-exhausts/
  • Replies 40
kakimoto's are great. I would always recommend them for NA's but you have to remember its going to said noticeably different to a turbo skyline. The regu 06 will drone from a NA because its a cannon without the hotdogs etc etc. If you get the kakimoto R, part NO. (NS310) 70mm Pipe - 115mm Tail would be the best performance wise for a NA.
its up to you
cannon
muffler
its up to you
cannon
muffler
Thanks mate, any idea what kind of kw i would be gaining from the kakimoto R?
Hannibalk1ng would be right there. Extractors would compliment the exhaust system. The main difference would be that buying a muffler would allow you to have more power through lower range (its better for street basically).
Getting that cannon catback Kakimoto make means the pipe is designed for turbo skylines so it will very droney and performance lacking on the street and even on the track you would have to reach the red line for it to feel different performance wise to a stock exhaust. Its designed for a turbo not NA, so unless its on the track at 6000-7000rpm it wont be able to be even as good as a stocker.
Thats why i would just get the muffler. Its like the stock design but functions better than it so its going to be better than it was before anyway.
Thanks for everything, I was just curious about the power gain but I dont need it. I just prefer the sound of the exhaust. The power is just a bonus for me.
Yeah I dont want much drone (a little is ok) so wat type of exhaust limits drone?
Edited by mick2nv
do not get a kakimoto exhaust i have one
when people get in the car for the first time they cannot believe how loud it is, ive never had someone in my car who hasnt made a comment about the exhaust.
spend the money at a exhaust shop and get a custom one made to suit your car
you will spend less, have a better note and a power increase
is it a cannon from Kakimoto or Kakimoto R??
the Kakimoto R model is quite and it can be loud when you but your foot flat but at least its not a loud drone as well......
Best best get one made up from any exhaust place. 2.5inch all the way and a cannon. probs looking at $ 350 installed.
but expect a drone while on the freeway doing 100kms
Thanks I'll take your advice and get one custom made.
Soon hopefully
LOL, the Full Mega N1 Hyper 2000 = Excessively loud, stock R34 with it was 113dB :P
It sounded tough though, on gearchanges it would "bark" and it scared small children. Downside was that after a good drive your ears would be ringing (true story)
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
