puts gtr80y to shame.
read the description carefully
more pics in the link.
is guy mad or what!
meggala
There was the vehicle inspection H14 year July 5th being cut off and a number, in travel distance 53000 km (at the time of 17000 km the engine placed and to change) had appeared in each magazine. " Engine specification " * & * RB20E (SOHC) Ë ƒeƒXƒ^ƒƒbƒT RB23DET (83 pie X 69.7 mm 2262 cc compression ratios 8.3: 1 full O/H valve seat cutting, connecting rod & piston weight adjusting and metal gasket. Turbine * & * trust TD06L2 full turbine kit (ƒGƒLƒ}ƒj, ƒGƒAƒCƒ“ƒNƒX and racing west gate, F pipe) 40000 km at time of full turbine exchange. " The part " * & * Tomei IN/EX260‹ high cam, the NISMO555 cc injector, Z32 air flow, the DENSO iridium plug X 6 NISMO strengthening clutch and the R33GTR fuel pump, the Ricoh racing CPU & the one off reversal full piping, the trust R33GTR preface intercooler & the blow off valve (you reset and process end) & the ƒvƒƒtƒFƒbƒN and the F tower bar, the ƒIƒvƒeƒBƒ}ƒoƒbƒeƒŠ[ and the endless NA-Y pad, the RRC titanium muffler for the Japanese drag race association R33GTR, the SUS304 straight pipe, the art garage make inner silencer -, each, heatproof cloth & the thermo- vantage measure being completed, the here and there WPC are processed in type. The urethane paint which " interior specification " * & * does not come off (a really denser blue) the FET ti basket KARO mat, the wife make combination skin shift cover, the RAZO each pedal and the fire master fire extinguisher, the autometer - 3911, the trust BOOST meter & oil pressure & oil temperature & water temperature & pillar meter and APEX multi-function REV meter, the trust shift knob and the ƒJƒƒbƒcƒFƒŠƒA cMd/CD deck, Al pine private house search function being attached wide DVD Nabi, the NISMO racing lighter/writer, the RECARO2 leg set and super low position rail X for the ƒCƒ“ƒeƒOƒ‰ cType-R 2, it modifies the MOMO steering wheel in the ƒCƒ^ƒ‹ƒ{ƒ‰ƒ“ƒe. " Appearance specification " * & * pot rice field drug specification! If each stickers are produced, peeling, automobile delivery desire, the yeast bear - the GTR grille, the top secret F bumper, NISMO side step & rear under, the aero magic R wing, the IMPUL fuel lid (it is useful to forgery key prevention) the NISMO hood top mall and the Encke I RS evolution 17 inch 7JJ X 8JJ aluminum wheel, DNA grand prix width F215 X R235 each 7 section mountain rank, the wide-tread attachment, the KYB climb gear & the kg / mm suspension. When " accident history the " after * & * CPU setting speed per hour 15 km rank travelling, the front left tire takes and one time the ƒPƒh which falls at all it is safe. For the left door slight illness applying escaping, being not to like, doing at the other looking with door exchange, and the signal waiting the ‚Ä ƒWƒƒWƒ being to depart, you think less than 10 - 20 km have appeared, but collision it was, (the bonnet has been dented a little) with total seeing, the pass and the circuit et cetera it has not attacked with grip and the drift. Being not to have either extreme accident please feel at rest. Sum total new model car + tuning cost = GTR new model car rank it was required, if (pain) it is possible, to like to do to hand in motor vehicle cassation being it does, but if there is desire, vehicle inspection you consult. Number is cut with something questions is the leprosy, don't you think?? Being to continue still exhibition ones please see in other things! As for bid with this way! Being to follow to other exhibition ones, there please see. Renewal being completed: July 14th 0 o'clock 13 minutes There to be a meaning, with DVD Nabi and removing RECARO Ë genuine, KARO mat Ë genuine and the 2DIN deck, the same ƒJƒƒbƒcƒFƒŠƒA the 2DIN of a little before (the CD/ cassette) making modify, being to receive, being cheap, because it offers the vehicle, we ask may.
https://www.sau.com.au/forums/topic/2744-is-this-skyline-rice/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
