Cheers for all the info there Henros, i know i'll be giving it a go!
easier than replacing the bulbs all the time!!!
question about setp 8, is that plugging straight into the original socket from the wedge globe? no mods needed here?
cheers again
Craved, the whole thing will plug straight in, no modes required.
Hippy, they are just normal 1/2 Watt metal film resistors, more than adequate as the power dissipation is less than 1/5 W. I'm not quite sure about the second part of your question. Do you mean the socket sitting under the PCB? That's the original socket for the parker bulb.
Bah...
I applaud your effort, but you can just buy these bulbs (with an LED matrix) from Raybrig or other bulb companies right off the shelf and plug it straight in.
No PCBs, No soldering, no measuring.
Autobarn should be able to hook you up, if not, try PD's Car Audio in Hornsby... They had heaps last time I checked.
Hippy, all white LEDs have a blueish tinge because they are essentially blue LEDs with an internal phosporous coating. The amount of blue various from manufacturer to manufacturer. You can get blue LEDs with different shades of blue. Jaycar for example, sell 470 nm blue and 505 nm blue/green LEDs.
Steve, the extra diode is there to provide reverse polarity and trasient high voltage protection, the IN4004 has a reverse breakdown voltage of 400V. LEDs have much lower reverse breakdown voltage. In reality tho, you could do without it, but you need to increase the value of the resistor as the diode helps to drop around 0.7V which now has to be shed by the resistor.
Merli, construction was half the fun, for me anyway. :D
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
