  • Replies 74
Yeah we watched that too....200mph around closed roads.....33 mile lap....they're idiots but I love it.
Yeah the Isle of Man TT is just insane! It was frightening just watching the onboard camera let alone actually riding it!!!!
Average speed of 130mph! Apparently 226 people have died on the circuit since 1907, but they just keep going faster and faster!
How was the Aussie Cameron Donald setting fastest lap in practice, then he had a stack and dislocated his shoulder and injured his back which obviously put him out of the event.
And then there's the side car guys!!! My god!!!! so awsome! Talk about having a death wish.
swoit....more to come tonight....
10pm Formula Drift
10:00pm - 11:00pm | One Digital G Sport, Repeat
High-powered motor sport action testing drivers' skill to control a car while it slides sideways at high speed through a marked course. It is judged on execution and style rather than who finishes the course fastest.
G(60)10:00pm - 11:00pm Isle of Man Tourist Trophy
worth watching!
Can't wait till this is available on Foxtel in the next month or 2, i keep forgetting about the channel and since getting Foxtel IQ I don't have the patience to sit down and watch shows live, only from the IQ box so I can pause and FF the ads.
yeah that sucked. I noticed a stack dash in one of those cars too, so they are not cheapies. It's amazing how many people in how many categories come up with 50-100K to build a race car.
Yeah i really felt sorry for him when the commentator mentioned there's virtually no sponsors in that series and the driver would just cop the fee to fix it.
DTM is on now - SO GOOD!!!!
Wow, I have it on Austar IQ. :worship: Have done since it was released. :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
