Hey guys
my 25 turned into a kettle Friday night, head gasket blew, looks like its been on the way for a while, little bit of corrosion on the block under the gasket, looks like the metal ring on the gasket has caught the edge of the piston, not sure if i should pull it down and go for broke or just fit a better gasket and see what happens!! has anyone seen this before?
https://www.sau.com.au/forums/topic/274707-suss-piston/
Hey guys
If that's the inlet side, it looks like the beginning of a piston melting.
Have you looked at the gasket in the same position to see if it also has similar damage? Usually the stocko head gasket will let go if detonation has been an issue for some time and the piston can cop some damage from the detonation but not before the gasket blows.
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656086
Righto, well it won't be a melted piston. Considering the damage on the gasket and the limited amount that can be seen on the piston, if it were my car, I'd be pulling the engine out and replacing or repairing it.
You could leave it if you wanted to but only the magical pixies know what damage could occur.
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656140
has the motor recently been rebuilt? piston looks very/too clean? was the gasket the right size for the bores if it is overbored? did you use both of those alignment thingies that sit around the head bolts
personally I would pull it apart for sure. they may be able to save the piston with some light machining but you don't want it scraping up and down the bore looking like that.
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656349
if you move the piston down the bore can you see any scores or marks ?
I would be pulling this engine appart regardless. I would dare say the rings are cracked as well.
The piston is very clean because this is a E85 engine :banana:
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656363
she's all factory, so i'm sure the gasket was the right size.
cant see any scores on the bore at all, just a few water marks, it is cleaner than the rest, most likely the steam and un-burnt e85 cleaning it!
https://www.sau.com.au/forums/topic/274707-suss-piston/#findComment-4656432
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
