18/06/09 Baskin's Meet With A Twist Of Car Detailing!
Yea i get it too lol, i posted up a pic on the "post up your 33" thread and the first guy said it looked awesome but they would burn my tail lights and then they all said +1 afterwards haha.
Why do they make such a big deal over "50RTU"?? :laugh: Id say mine looked better really.... :D
+1 for wtf so special about 5ORTU, like its a tidy car but pretty plain all round.
Edited by Danski
  • Replies 294
i think that is the actual point, a lot of ppl make over-the-top body mods.. all hes done was find nice wheels to match the colour of the car with the right offset and a respray, instead of those full on body kits and nothing-to-do-with-the-car wheels..
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
