it has day/night transition
should also point out that the november 2 release date is for north america. it is expected that it will be worldwide, but no confirmation yet. so we may not get it until a few weeks after that, however i think it would definately be before xmas as sony australia would be down right stupid to leave the release date until after xmas
Finally! Couldn't sleep last night knowing that the press conference was at 5am and by the time I wake up there would hopefully be a release date. The collectors edition looks nice, I'll be getting one of those...now I just need to get a ps3 and a new tv :thumbsup:
Theres also supposed to be a closed door session with Kaz to the media about new information and new features on wednesday which should be about thursday for us. Hoping for more info about online :thumbsup:
http://www.racesimcentral.com/news/lang/it...dule-of-events/
tow-ring? you mean the keyring? yeah i saw it.
not sure where you will be able to pre-order it. i'm guessing it will be a few weeks before even the shops know about it, at least. it's still about 6 months away so i don't think sony will be rushing too much with getting all the info out. probably leave it until they send out the statements to their customers at the end of the month.
november 2nd bitches!!!!!!!!
also the collectors edition you will get a 1:43 scale r35 gtr and some bonus cars for in the game. not sure if you have to pre-order it or not
About FKN TIME!!!!!!!!!!!!!
This game will either be the ULTIMATE driving simulator or it's going to make A LOT of people unhappy... whatever the case, I'm getting it.
I dont know about you guys but I've just pre-ordered my Collector's Edition. :P
If you did preorder, then it's probably an overseas version.
Be EXTREMELY careful when preordering from overseas. I bought my ultimate edition God of War 3 from overseas and I had no access to the exclusive content. The extra skins and playable arena required a US account (won't allow me to even use these with my AUS account) and downloading the exclusive soundtracks and videos actually required me to LIVE in the US, for some stupid reason.
ok i'm rethinking putting a pre-order in for gt5 collectors edition because of the price. it is going to be $99US. the last game to be $99US was god of war 3 ultimate, which sells here for $250, but that was exclusive to ebgames. but even just based off other prices it is going to be expensive. most games over there go for about $60 (regular gt5 is listed at $60US) and $120 here, so at $99 you can expect it to be double that, so at least $200. don't think i'm that much of a gt fan. i think i'll stick with the normal edition.
was just doing a bit of digging around (that's how i found out about the price) and found an aussie site where guys were saying that they had put pre-orders on at ebgames (in australia, not online). some had put down deposits. not sure if it was required or not. but still no official australian release date. apparently all will be revealed at the european E3 or whatever it's called in august. that is supposed to be when the full reveal of the game is, not just letting people see demo's etc. all the features of the game will be revealed... aparently.
+1
Sometimes collector's editions aren't worth the price. GT5 has always been good for the gameplay so I'll most likely just stick with the regular version.
Unless the developers do something crazy and include online access only with the collector's edition, I may consider getting that one instead.
I'm in it for the physical contents - but additional cars in-game would be a bonus.
Game Stop had the Metal Gear Solid: Peace Walker Limited Edition but Australia didnt get it - lucky I pre-ordered it from the US! But if Australia does get the GT5 Collector's Edition I could always put a pre-order down here and cancel the Game Stop pre-order(since they dont take deposits anyway its no lost).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
