# Polyphony Digital is working on reducing load times and is still tweaking graphics ahead of the November release date.
# The game has nearly filled all of the space available on Blu-Ray disc.
# You’ll have the option to synchronize the game’s time of day with the track’s current local time.
# The crowds will be dynamic, so there will be more tents, cars, and motorhomes at longer races.
# Yamauchi admits his team may have “actually gone too far in modeling some of this detail” and suggested it might be “more suited to the next generation of PlayStation.”
# Both high and low-beam headlights will be included, so you can flash slower cars as you’re about to pass them (how awesome will this be during the 24 hour races!?!). All lights will illuminate dirt, smoke, or other debris in the air.
# NASCAR insisted that all of their series’ cars be playable on all circuits in the game.
# It was previously mentioned that only 9 NASCAR cars will be included, but this was incorrect. There are simply 9 cars in the E3 2010 demo, but “many more” are coming.
# With the exception of profanity, all of the Nurburgring’s graffiti has been re-created, just as it is in real life. According to Kotaku, they will attempt to keep the graffiti up-to-date before the game is shipped.
# Players will be able to maintain an online profile to share and watch friend’s progress and statistics.
# All cars (including standard models) will accumulate dirt and will have functional horns.
# All cars will have functioning reverse lights.
# More information will be revealed at Gamescom in Germany on August 18-22.
# More Formula 1 teams will bring their cars to the game, in addition to Ferrari.
pretty cool stuff, especially being able to synch the actual time of day with that of the race
For the amount of time they've had to work on the game, it's an expectation to have all of these small details in it. Then again, it's the smaller details that separate a good game from a great game.
At least we know Polyphony have pushed the PS3 to its limits... It's going to be EPIC.
And for Mr Eps, I remember making no such bet... :D
Translation: Frame rates can get pretty horrible.
This ought to bring back some great memories...
Whether you had the full game or just played it on Demo1.
that reminds me of the old NFS games. about 6 months ago i loaded nfs highstakes up here at work and was playing it and it's music sounds a lot like that too. brought back memories of the good old days
I believe you are referring to Paradigm Shifter...
By far, the best NFS game EVER!!! Followed closely by the Underground series.
PM me if anyone wants any of these songs. I have them both in MP3 format off their soundtracks.
Do you have the soundtrack for NFS Porsche Challenge/Porsche Unleashed? I have been looking for it for ages.
that's the one
Forza 3 - released October 23 2009
GT5 - Not yet released
GT5 will end up being compared to Forza 4 anyway.
+ ps3 is blu-ray, x-box isn't, so you have to expect some graphics differences. however i don't think you can put that much down to the release date. a lot of the waiting time was them getting it sorted for 3D and playstation move. however yes they have been developing the game for longer even before that. but then if they hadn't been spending time on getting GT5P out and all that crap it may have been out already.
You mean the 'demo that you pay for'. BD allows more models and textures and higher res textures so more cars and supposedly more stuff around the track however it doesn't make the PS3 GPU any faster.
Sorry Taz, I don't have that one.
BUT
You might find it in the new thread I just made,
SOUNDTRACK - Video Games
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
