anyone come across a nismo xanavi R34 GTC? i want it
has anyone seen one in the used section? i dont think its a prize car
i had it in my used car lot yesterday. can't remember how much it was, but it was under 1 million. think it was around $800,000.
I had another go at the level 15 rally last night.first time i was in an evo 10 and was getting smashed. bought myself a corolla rally car for $250,000 and hd no problems winning. in the snow race i won by just under 2 mins. i was over taking the 2 cars in front and in 1 stage i was right behind the 1st car. tat stage i won by 32 seconds.
same... snow was a bit ridiculously easy
Ok... Got Gold in the Kombi challenge... Top gear track unlocked.
Got bronze in the Elise top gear challenge finally... Fk I hate that car with those tyres! But I'll persist n crack a few narnies along the way n eventually I'll get it.
On the b'day car thing... Where is my b'day data held??? I don't remember having to put it in my ps acct. details... N couldn't find it when I checked
oh u were being serious about that?? are you meant to get something in gt5 on ur bday?
i think birthday details are essential items when you sign up i.e it wont let you register without it.
Does any one else wish they didn't bother with the B-Spec events and just made the A-Spec events bigger or just added more events to the game?
I mean, I buy the game to play it, not to have half the game played for me. While I enjoying watching the videos of the car driving, I feel that's what the "Playback" is for, not to have half the game devoted to it...
Dam this game is addictive. spent just about all day on this today.
i've also found out how to record gameplay footage, you need to use the composite ( red,yellow,white) cables, and plug it into a DVD recorder. record what you want. then just finalize the disc, shove it in the PC and record it again using fraps. then edit in your video editing software and output it in the file type you want.
The quality is deffinatly not the best ( dam composite cables). and its a bit of screwing around aswell. but it works and is watchable.
Edited by liger
the only thing that pisses me off about replay when you go into photo mode you cant slow down playback and go slow forward, slow backward and pin point the frame you want. it would be mint if you could then you could really get the exact shot you wanted. heres a couple of mine
true dat.....on this note. should we start a thread for cool GT5 shots??
on another note. i was playing online the other evening and i couldnt find any aussie servers, so i opened it up to find all. and to my excitement i found a Japanese server (couldnt read anything) around Tsukuba with 6 RX7's and RX8's formation drifting. looked SWEEEEET, so i pulled up on the side of the road in my kombi and just watched em for a while...dam they were good
Edited by boiracer
you mean to say you hadn't got golds on the sebastian loeb challenge and won his car?? made for easy work on the gt rally
and if someone comes across the xanavi nismo r34 you should buy it, gift it to me and i'll gladly return the favour if/when i come across something your looking for
no i haven't got golds on the seb loeb rally challenge. i got all bronze and really CBF'd trying them again. the rally events in general in GT5 haven't really sparked my interest so i am simply doing them to pass them to get them out of the way. if i happen to get gold first time (which i have so far in the GT rally events) then good, if i only get bronze or silver then meh, at least i passed. i actually prefer the B spec to some of the rally events. just wish my drivers would realise that if they are in a lambo LP640 and the car in front is a little hatch back and they are faster than it, that by using the big round thing on the dash in front of them they can go around the car in front.
Got gold on the first one... from memory i was bronze on the 2nd one but only had 2 or 3 cracks at it so far. Will devote some time this coming weekend and grind away.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
