as the title says ive got a genuine trust T88-33D turbo, trust 60mm type C w/gate and genuine trust exhaust manifold aswell as a dump pipe to suit an r32
this set up is for an rb26.
i only bought this turbo off a fellow forum member a couple of weeks ago but due to my engine build being cancelled im no longer going to need this turbo.
previous owner stated its only 12 months old
there is no shaft play or anything in the turbo
has oil and water lines supplied
im very dissapointed to let this go as i realy wanted to use it on my engine
items are located in wollongong NSW
would prefer pick up as its very heavy but if you want to arrange a courier thats up to you
price is $3000 which i was i paid for it
https://www.sau.com.au/forums/topic/274798-t88-turbo/
hey mate,
i have 18" rays rims if your interested
these are the Rays C-ultra (Volk racing) however they have a stud pattern of 5x100 they have come off a R33 GTR
let me know if your interested at all
i have a random pic off ebay exactly the same but not my exact rims
https://www.sau.com.au/forums/topic/274798-t88-turbo/#findComment-4763261
hey mate,
Nah sorry mate not interested.
I no longer want rims as i bought a set a month ago so cash sale only
https://www.sau.com.au/forums/topic/274798-t88-turbo/#findComment-4763971
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
