Hey guys, i've decided to put my wheels up for sale.
front: 17 x 7 + 5 offset (1.5" dish) ~60-70% tread
rear: 17 x 8 + 5 offset (2" dish) ~ 50-60% tread
PCD: 5 x 114.3
the tyres are Pirella P-zero Rocci ($280 brand new each)
Price: $1100
Located in Sydney
Rays GTC black internal drive lug nuts for free!
Edited by ky0
I am interested. Looking to go on an s15. Did you have any problems fitting the wheels inside the guards of the s14?
never had a problem on the s14. the guards have not been flared or rolled and never had an issue with scrubbing.
  • 3 weeks later...
trade for my super advan tri spokes... nice and lightweight with near new tyres, i only drove on the front pair for around 4 thousand KM's before i got rid of my old car.
let me know, would def be keen for something different
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
