  • Replies 46
This is my Pedders experience.
Had the wheel alignment done on my R33GTS-T and it came back with a large scratch in the left rear quarter panel - which they obviously denied doing. Had a great fight with them when I asked them to use Gary's (Sydneykid) settings for the wheel alignment - they did it but with much complaining and probably resulted in the scratch.
Prices are very expensive - 12mm camber bolts Pedders = $115, Whiteline $79
The only thing going for them is that they stock front ball joints for R32/R33/R34 GTS-T's.
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826267
so they measured up my car to see how much lower it will be with there sports ryder springs. (i have nismo s type struts and an unknown but firm spring, that i figured was stockish height)
aparently they will raise the car 10mm both ends. wtf type of lowering spring is that!!!
*starts saving for coilovers* (not pedders)
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826489
meh pedders here don't even stock more than about 4 parts for R32 GT-R/4 suspension and the guy took a look at my car and says 'hmm haven't seen many of those', would rather get stuff done at goodyear - at least the guys there had a good idea of how an R32's suspension works!
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-4826585
  • 11 months later...
Hi all, first time poster and owner of a skyline R34. went to get it looked at by a local mechanic coz the steering wheel was vibrating a bit on idle. He said I needed to get the front radius rod bushes replaced and suggested I go to pedders coz it's an import.
So I go to pedders and got them replaced for $260 but then they told me that they couldnt do the wheel alignment coz the steering gear is leaking internally and will cost another $1100 odd dollars to fix.
Just wanted to know if this sounded reasonable and should I be looking around elsewhere to see if it is bull. Can anyone recommend someone in melbourne, particularly in the western suburbs?
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-5428632
No it's not reasonable. A second hand steering rack should only be 300 or so, and it isn't that much in labour to install. Also, I can't see how a leak would prevent them from doing a wheel alignment. Just go somewhere else to get the alignment done.
https://www.sau.com.au/forums/topic/274952-pedders/page/3/#findComment-5431439
    • Noice. Congrats on the big day too!   don’t forget to never eat in the Skyline 🤣
    • Overnight parts from Amazon, let's go. Replaced nearly every o-rings, minus 2x from the pumps. Seems the kit is short? Then again when I replaced the main pump a few years back it did come with new seals so we are good. Yiewwww, ready for legal stimulants.
    • I'm only really familiar with the R33 setup, the factory filter is very much an encourage fuel pick up thingo.  The factory pump sits about half way down into the tank and the sock runs down into the bottom of the tank.  Mounting an aftermarket pump in the factory location with the typical tiny Walbro filter, I had huge fuel surge issues once the fuel level dropped below 50%.
    • Hi Gent, Got my r34 GTT 1999 ,wondering if anyone has a stock airbox with snorkel? currenly it has a pod filter which im planning to remove and install the stock part, as this needs to go to vic road for inspection. Appreciate your assistance.
    • Yeah, I still dunno. The size of the sock should only matter if it is blocked. It is, after all, a filter rather than a "thing to encourage fuel pickup". He has modded the original so that it is now down on the floor, so it's not physically the same as in the original complaint, yet does the same thing. I therefore lean to the problem being somewhere else. Sticking some dynomat on there is a worthwhile experiment, but I'd put $10 on it not fixing the problem.
